New Build with GTX 1070, Numerous Problems
HooblaDan
Commendable
Aug 5, 2016
Hello all, and thank you up front for any help that you can provide.
My brother's friend recently helped me build a new computer. He has good knowledge of the initial build but does not know much more than I do as far as maintenance once the computer is up and running.
It combines an AMD motherboard with the new MSI Gaming X GTX 1070 card, which was supposed to be great. Unfortunately, the program to control lights and other features on the card is not currently functioning. MSI forums tell me that this is a compatibility issue that all GTX 1000 models are suffering with AMD motherboards. Yay me. Hopefully the driver fixes this at some point.
However, it's also having a few other problems:
1. Frequently on initial start-up, the system will boot but nothing will display on the monitor, and the monitor will state that there is no display. This is always fixed by hitting the small reset button on my case, but it happens with a fair amount of frequency and it concerns me greatly.
2. When downloading programs with Steam or GoG Galaxy, the computer stutters and sometimes crawls to a halt if I try to play any video. Sometimes, the display drivers will stop working. This problem seems to go away if I significantly throttle the download speed to below 10MB (I have very good internet so this sucks as a solution).
3. Performance out of the system is middling from numbers that I have read from others with weaker specs. Witcher 3 on Ultra 1080p, for instance, runs 60 with some small dips into 50s. I've read of others with what I understand to be weaker processors getting 70-80. In addition, performance in a variety of games, including WoW, Guild Wars 2, and Total War Rome 2 is disappointing, with some incredibly low framerates at points.
I would appreciate any help in fixing this system up. I just had it built in June and would prefer not to have to spend additional money on new parts, but it can be done if it means getting better performance out of the GPU.
So far I have tried a clean GPU driver install and have updated numerous system drivers, such as Killer Network, in an attempt to improve these problems. Nothing has worked so far. Copied below is my dxdiag in case it helps. Please do not hesitate to ask any additional questions that may be of assistance.
I own a 1070 as well and have been noticing weird things as well. Apparently there's some DPC Latency issues with the newer cards and that can cause the video issue you were discussing.
Here is the link to the thread, it's pretty big: https://forums.geforce.com/default/topic/523477/nvidia-drivers-causing-high-dpc-latency-thus-making-sound-crackle-and-drop-out/
Recently a representative of nvidia said on the forums that they're fixing this soon, I hope this will fix all the issues we seem to be having.
Here's his statement (Also in the linked thread): http://puu.sh/qrzbl.png
You can see on a program called "Latencymon" that launching games and other activities cause your system to be delayed slightly and may cause dropouts of audio...
System Information
Time of this report: 8/4/2016, 23:26:24
Machine name: DESKTOP-5S8EM59
Operating System: Windows 10 Pro 64-bit (10.0, Build 10586) (10586.th2_release_sec.160630-1736)
Language: English (Regional Setting: English)
System Manufacturer: MSI
System Model: MS-7893
BIOS: BIOS Date: 12/24/15 09:11:48 Ver: 04.06.05
Processor: AMD FX(tm)-9590 Eight-Core Processor (8 CPUs), ~4.7GHz
Memory: 16384MB RAM
Available OS Memory: 16332MB RAM
Page File: 5458MB used, 13304MB available
Windows Dir: C:\Windows
DirectX Version: 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10586.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 1070
Manufacturer: NVIDIA
Chip type: GeForce GTX 1070
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_1B81&SUBSYS_00000000&REV_A1
Display Memory: 16311 MB
Dedicated Memory: 8145 MB
Shared Memory: 8165 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um,nvwgf2um
Driver File Version: 10.18.0013.6881 (English)
Driver Version: 10.18.13.6881
DDI Version: 12
Feature Levels: 12.1,12.0,11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 2.0
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 7/10/2016 12:00:00 AM, 17463992 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-58C1-11CF-5179-0D201CC2C735}
Vendor ID: 0x10DE
Device ID: 0x1B81
SubSys ID: 0x00000000
Revision ID: 0x00A1
Driver Strong Name: oem33.inf:0f066de361866ac3:Section062:10.18.13.6881😛ci\ven_10de&dev_1b81
Rank Of Driver: 00D10003
Video Accel:
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0900&SUBSYS_1462D893&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.7855 (English)
WHQL Logo'd: Yes
Date and Size: 6/21/2016 12:00:00 AM, 5179648 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output(Optical) (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Acer H226HQL-4 (NVIDIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0083&SUBSYS_14623302&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.03.0034.0015 (English)
WHQL Logo'd: Yes
Date and Size: 5/10/2016 12:00:00 AM, 214592 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0xF1F
HW Memory: 0
Description: Realtek Digital Output (Realtek High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Razer Naga
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x002E
FF Driver: n/a
Device Name: Razer Lycosa
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x0109
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4397
| Matching Device ID: USB\ROOT_HUB
| Service: usbhub
| Driver: usbhub.sys, 10/30/2015 00:17:23, 500064 bytes
| Driver: usbd.sys, 10/30/2015 00:17:23, 30048 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 10/30/2015 00:17:23, 159072 bytes
| +-+ Razer Naga
| | | Matching Device ID: usb\vid_1532&pid_002e&mi_00
| | | Service: HidUsb
| | | Driver: RzWizardPkg.exe, , 0 bytes
| | | Driver: hidusb.sys, 10/30/2015 00:17:23, 38400 bytes
| | | Driver: hidclass.sys, 5/27/2016 21:23:26, 155136 bytes
| | | Driver: hidparse.sys, 10/30/2015 00:17:23, 40448 bytes
| | | Driver: RazerCoinstaller.dll, 4/12/2016 07:20:52, 95400 bytes
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 10/30/2015 00:17:23, 32256 bytes
| | | | Driver: mouclass.sys, 10/30/2015 00:17:23, 59232 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 10/30/2015 00:17:23, 36864 bytes
| | | | Driver: kbdclass.sys, 10/30/2015 00:17:23, 62304 bytes
| | Service: usbccgp
| +-+ Razer Lycosa
| | | Matching Device ID: usb\vid_1532&pid_0109&mi_00
| | | Service: HidUsb
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 58.8 GB
Total Space: 228.4 GB
File System: NTFS
Model: MKNSSDE3240GB
Drive: E:
Free Space: 280.6 GB
Total Space: 953.7 GB
File System: NTFS
Model: WDC WD10EZEX-60WN4A0
Drive: D:
Model: ASUS DRW-24B1ST j
Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.10586.0000 (English), 10/30/2015 00:17:22, 173568 bytes
System Devices
Name: VIA USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_1106&DEV_3483&SUBSYS_78931462&REV_01\4&693E52D&0&00AB
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.10586.0212 (English), 3/29/2016 01:21:40, 378208 bytes
Name: ASMedia USB3.1 eXtensible Host Controller (ASM1143)
Device ID: PCI\VEN_1B21&DEV_1343&SUBSYS_78931462&REV_00\4&36B381C0&0&0020
Driver: C:\Windows\system32\DRIVERS\asmtxhci.sys, 1.16.0028.0001 (English), 9/17/2015 11:29:18, 443128 bytes
Device ID: PCI\VEN_1002&DEV_43A0&SUBSYS_00001002&REV_00\3&11583659&0&A8
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.10586.0494 (English), 6/30/2016 21:35:00, 331616 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1601&SUBSYS_00000000&REV_00\3&11583659&0&C1
Driver: n/a
Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_1002&DEV_4391&SUBSYS_78931462&REV_40\3&11583659&0&88
Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.10586.0000 (English), 10/30/2015 00:17:23, 133984 bytes
Device ID: PCI\VEN_1002&DEV_5A14&SUBSYS_78931462&REV_02\3&11583659&0&00
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_439D&SUBSYS_78931462&REV_40\3&11583659&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.10586.0000 (English), 10/30/2015 00:17:23, 18784 bytes
Device ID: PCI\VEN_1002&DEV_43A3&SUBSYS_00001002&REV_00\3&11583659&0&AB
Device ID: PCI\VEN_1022&DEV_1604&SUBSYS_00000000&REV_00\3&11583659&0&C4
Driver: n/a
Device ID: PCI\VEN_1002&DEV_5A18&SUBSYS_78931462&REV_00\3&11583659&0&20
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_78931462&REV_00\3&11583659&0&B0
Driver: C:\Windows\system32\drivers\usbohci.sys, 10.00.10586.0000 (English), 10/30/2015 00:17:23, 29696 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 10.00.10586.0000 (English), 10/30/2015 00:17:23, 454496 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 10.00.10586.0000 (English), 10/30/2015 00:17:23, 500064 bytes
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_78931462&REV_00\3&11583659&0&98
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_78931462&REV_00\3&11583659&0&90
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_40\3&11583659&0&A4
Name: SM Bus Controller
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_78931462&REV_42\3&11583659&0&A0
Driver: n/a
Name: NVIDIA GeForce GTX 1070
Device ID: PCI\VEN_10DE&DEV_1B81&SUBSYS_00000000&REV_A1\4&3CB21C6&0&0010
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 456640 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 7/10/2016 19:34:13, 1339104 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_87aa927b5db9eb5e\NvCplSetupInt.exe, 1.00.0005.0000 (English), 7/10/2016 19:34:13, 97014200 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0207 (English), 7/10/2016 19:34:13, 20536 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvd3d9wrap.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 186888 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 115288 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0207 (English), 7/10/2016 19:34:13, 18880 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvd3d9wrapx.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 216592 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 135680 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 7/10/2016 19:34:13, 26629 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 7/10/2016 19:34:13, 849976 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 411704 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 7/10/2016 19:34:13, 74003 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.6881 (English), 7/10/2016 19:34:13, 447936 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.6881 (English), 7/10/2016 19:34:13, 816184 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.02.0011.0000 (English), 7/10/2016 19:34:13, 203320 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.02.0011.0000 (English), 7/10/2016 19:34:13, 213952 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 10.18.0013.6881 (English), 7/12/2016 22:40:58, 13675576 bytes
Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 999872 bytes
Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 930360 bytes
Driver: C:\Windows\system32\NvIFROpenGL.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 444472 bytes
Driver: C:\Windows\system32\nv-vk64.json, 7/10/2016 19:34:13, 594 bytes
Driver: C:\Windows\system32\nvDecMFTMjpeg.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 383936 bytes
Driver: C:\Windows\system32\nvEncMFTH264.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 802816 bytes
Driver: C:\Windows\system32\nvEncMFThevc.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 801792 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 413488 bytes
Driver: C:\Windows\system32\nvapi64.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 3825688 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 7/10/2016 19:34:13, 39977920 bytes
Driver: C:\Windows\system32\nvcuda.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 10243600 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0013.6881 (English), 7/10/2016 19:34:13, 2868160 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 17463992 bytes
Driver: C:\Windows\system32\nvfatbinaryLoader.dll, 7/10/2016 19:34:13, 694488 bytes
Driver: C:\Windows\system32\nvinfo.pb, 7/10/2016 19:34:13, 40084 bytes
Driver: C:\Windows\system32\nvinitx.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 177952 bytes
Driver: C:\Windows\system32\nvmcumd.dll, 7/10/2016 19:34:13, 612064 bytes
Driver: C:\Windows\system32\nvoglshim64.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 153232 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 31680568 bytes
Driver: C:\Windows\system32\nvopencl.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 10700592 bytes
Driver: C:\Windows\system32\nvptxJitCompiler.dll, 7/10/2016 19:34:13, 10656296 bytes
Driver: C:\Windows\system32\nvumdshimx.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 563856 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 20417200 bytes
Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 909248 bytes
Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 852024 bytes
Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 393152 bytes
Driver: C:\Windows\SysWow64\nv-vk32.json, 7/10/2016 19:34:13, 594 bytes
Driver: C:\Windows\SysWow64\nvDecMFTMjpeg.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 348216 bytes
Driver: C:\Windows\SysWow64\nvEncMFTH264.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 644184 bytes
Driver: C:\Windows\SysWow64\nvEncMFThevc.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 642440 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 345800 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 3382240 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 7/10/2016 19:34:13, 35117112 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 8622576 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0013.6881 (English), 7/10/2016 19:34:13, 2497984 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 14487768 bytes
Driver: C:\Windows\SysWow64\nvfatbinaryLoader.dll, 7/10/2016 19:34:13, 583920 bytes
Driver: C:\Windows\SysWow64\nvinit.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 155952 bytes
Driver: C:\Windows\SysWow64\nvoglshim32.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 131584 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 25442240 bytes
Driver: C:\Windows\SysWow64\nvopencl.dll, 6.14.0013.6881 (English), 7/10/2016 19:34:13, 9028360 bytes
Driver: C:\Windows\SysWow64\nvptxJitCompiler.dll, 7/10/2016 19:34:13, 8742360 bytes
Driver: C:\Windows\SysWow64\nvumdshim.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 462904 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 10.18.0013.6881 (English), 7/10/2016 19:34:13, 17764408 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_87aa927b5db9eb5e\VulkanRT-Installer.exe, 1.00.0011.0001 (English), 7/10/2016 19:34:13, 13605464 bytes
Driver: C:\Windows\system32\nvdispco6436881.dll, 2.00.0045.0004 (English), 7/10/2016 19:34:13, 1939000 bytes
Driver: C:\Windows\system32\nvdispgenco6436881.dll, 2.00.0021.0002 (English), 7/10/2016 19:34:13, 1571776 bytes
Device ID: PCI\VEN_1022&DEV_1602&SUBSYS_00000000&REV_00\3&11583659&0&C2
Driver: n/a
Device ID: PCI\VEN_1002&DEV_5A16&SUBSYS_78931462&REV_00\3&11583659&0&10
Name: High Definition Audio Bus
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_D8931462&REV_40\3&11583659&0&A2
Driver: C:\Windows\system32\DRIVERS\amdkmafd.sys, 8.14.0001.6003 (English), 6/3/2015 06:35:36, 31992 bytes
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.10586.0000 (English), 10/30/2015 00:17:18, 79872 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.10586.0000 (English), 10/30/2015 00:17:19, 97280 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.10586.0212 (English), 3/29/2016 00:34:50, 333824 bytes
Device ID: PCI\VEN_1022&DEV_1605&SUBSYS_00000000&REV_00\3&11583659&0&C5
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1600&SUBSYS_00000000&REV_00\3&11583659&0&C0
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_10F0&SUBSYS_33021462&REV_A1\4&3CB21C6&0&0110
Device ID: PCI\VEN_1022&DEV_1603&SUBSYS_00000000&REV_00\3&11583659&0&C3
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_78931462&REV_00\3&11583659&0&B2
Driver: C:\Windows\system32\drivers\usbehci.sys, 10.00.10586.0000 (English), 10/30/2015 00:17:23, 95584 bytes
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_78931462&REV_00\3&11583659&0&9A
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_78931462&REV_00\3&11583659&0&92
Name: Killer E2200 Gigabit Ethernet Controller
Device ID: PCI\VEN_1969&DEV_E091&SUBSYS_78931462&REV_13\4&2DDBB3B7&0&00A8
Driver: C:\Windows\system32\DRIVERS\e2xw10x64.sys, 9.00.0000.0037 (English), 2/12/2016 11:30:28, 162456 bytes
Device ID: PCI\VEN_1002&DEV_5A23&SUBSYS_78931462&REV_00\3&11583659&0&02
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_78931462&REV_00\3&11583659&0&A5
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.10586.0063
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.10586.0063
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.10586.0063
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.10586.0063
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.10586.0000
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.10586.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.10586.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.10586.0000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.10586.0000
DV Muxer,0x00400000,0,0,qdv.dll,10.00.10586.0000
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.10586.0071
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.10586.0000
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.10586.0071
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.10586.0071
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.10586.0494
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.10547.1000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.10586.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.10586.0494
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.10586.0071
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.10586.0071
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.10586.0071
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.10586.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.10586.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.10586.0000
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.10586.0494
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10586.0035
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.10586.0071
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.10586.0071
DV Splitter,0x00600000,1,2,qdv.dll,10.00.10586.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.10586.0071
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,12.00.10586.0035
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.10586.0071
Video Renderer,0x00800001,1,0,quartz.dll,10.00.10586.0071
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.10586.0494
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.10586.0071
Video Renderer,0x00400000,1,0,quartz.dll,10.00.10586.0071
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.10586.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.10586.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.10586.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.10586.0494
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10586.0035
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.10586.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.10586.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.10586.0000
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.10586.0063
Null Renderer,0x00200000,1,0,qedit.dll,10.00.10586.0063
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.10586.0000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.10586.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.10586.0494
Smart Tee,0x00200000,1,2,qcap.dll,10.00.10586.0000
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.10586.0071
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.10586.0071
Wave Parser,0x00400000,1,1,quartz.dll,10.00.10586.0071
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.10586.0071
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.10586.0071
File stream renderer,0x00400000,1,1,quartz.dll,10.00.10586.0071
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,12.00.10547.1000
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.10586.0494
AVI Mux,0x00200000,1,0,qcap.dll,10.00.10586.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.10586.0071
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.10586.0071
File Source (URL),0x00400000,0,1,quartz.dll,10.00.10586.0071
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.10586.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.10586.0071
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.10586.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.10586.0071
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.10586.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.10586.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.10586.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.10586.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.10586.0071
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.10586.0063
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.10586.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.10586.0071
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.10586.0071
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.10586.0071
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.10586.0071
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.10586.0071
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.10586.0071
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.10586.0000
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.10586.0000
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.10586.0000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.10586.0071
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.10586.0071
WDM Streaming Capture Devices:
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Realtek HDA SPDIF Optical Out,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Realtek HD Audio 2nd output,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10586.0000
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10586.0000
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10586.0000
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10586.0000
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.10586.0000
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.10586.0000
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.10586.0000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.10586.0000
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.10586.0000
PTFilter,0x00200000,0,0,EncDec.dll,10.00.10586.0000
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.10586.0000
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.10586.0071
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.10586.0071
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.10586.0071
DirectSound: Realtek Digital Output(Optical) (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.10586.0071
DirectSound: Acer H226HQL-4 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,10.00.10586.0071
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.10586.0071
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.10586.0071
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
AMD D3D11 Hardware MFT Playback Decoder, {17796AEB-0F66-4663-B8FB-99CBEE0224CE}, 0x4, 8
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpeg.dll, 10.18.0013.6881
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 12.00.10547.1000
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.10586.0000
Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.10586.0000
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.10586.0000
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 12.00.10547.1000
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.10586.0000
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.10586.0000
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.10586.0000
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.10586.0000
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.10586.0000
Video Encoders:
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264.dll, 10.18.0013.6881
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevc.dll, 10.18.0013.6881
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.10586.0000
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.10586.0000
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.10586.0000
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.10586.0000
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 12.00.10586.0035
H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.10586.0000
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.10586.0000
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.10586.0000
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.10586.0000
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.10586.0000
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.10586.0000
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 12.00.10586.0122
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.10586.0000
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.10586.0000
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.10586.0063
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.10586.0000
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 12.00.10586.0122
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 12.00.10586.0122
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.10586.0063
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.10586.0122
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.10586.0000
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.10586.0063
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 12.00.10586.0122
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 12.00.10586.0122
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.10586.0063
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.10586.0000
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 12.00.10586.0122
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, winmde.dll, 12.00.10586.0494
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 12.00.10586.0122
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.10586.0000
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.10586.0063
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.10586.0000
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 12.00.10586.0035
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.10586.0000
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.10586.0000
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.10586.0000
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.10586.0000
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.10586.0000
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.10586.0000
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 12.00.10586.0122
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 12.00.10547.1000
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
{43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 126657400413, type 5
Event Name: MpTelemetry
Response: Not available
Cab Id: 0
Problem signature:
P1: unspecified
P2: HardeningTelemetry
P3: HardeningTelemetryDisableAS
P4: 4.9.10586.494
P5: unspecified
P6: unspecified
P7: unspecified
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket 126657400317, type 5
Cab Id: 0
Problem signature:
P1: unspecified
P3: HardeningTelemetryDisableAV
P4: 4.9.10586.494
P5: unspecified
P6: unspecified
P7: unspecified
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket 120495399094, type 4
Event Name: APPCRASH
Cab Id: 0
Problem signature:
P1: NvStreamNetworkService.exe
P2: 7.1.2084.9592
P3: 57605ac0
P4: MessageBus.dll
P5: 0.0.0.0
P6: 5760534f
P7: c0000005
P8: 0000000000010f73
P9:
P10:
+++ WER3 +++:
Fault bucket , type 0
Cab Id: 0
Problem signature:
P1: unspecified
P4: 4.9.10586.494
P5: unspecified
P6: unspecified
P7: unspecified
P8:
P9:
P10:
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: unspecified
P4: 4.9.10586.494
P5: unspecified
P6: unspecified
P7: unspecified
P8:
P9:
P10:
+++ WER5 +++:
Cab Id: 0
Problem signature:
P2: 7.1.2084.9592
P3: 57605ac0
P4: MessageBus.dll
P5: 0.0.0.0
P6: 5760534f
P7: c0000005
P9:
P10:
+++ WER6 +++:
Cab Id: 0
Problem signature:
P2: 7.1.2084.9592
P3: 57605ac0
P4: MessageBus.dll
P5: 0.0.0.0
P6: 5760534f
P7: c0000005
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P2: 7.1.2084.9592
P3: 57605ac0
P4: MessageBus.dll
P5: 0.0.0.0
P6: 5760534f
P7: c0000005
P9:
P10:
+++ WER8 +++:
Fault bucket 128948929420, type 5
Event Name: RADAR_PRE_LEAK_WOW64
Cab Id: 0
Problem signature:
P1: RocketLeague.exe
P2: 1.0.10897.0
P3: 10.0.10586.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER9 +++:
Fault bucket 128951104083, type 5
Cab Id: 0
Problem signature:
P1: DCApp.exe
P2: 1.0.124.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
You can see on a program called "Latencymon" that launching games and other activities cause your system to be delayed slightly and may cause dropouts of audio and video. For me is shows the Nvidia driver as one of the biggest causes of latency so I'm hopeful that this will be fixed.
