I put together a new PC today and when I hit the power button, the power led comes on, mobo light comes on, PSU / CPU fan both spin, but there's no beep or post on the monitor using VGA. I do have the mobo speaker plugged in, and no beep at all. I've read the sticky thread and gone through all the steps, I'm using the stand-off screws correctly, I've tried only using 1 stack of Ram and I've tried both ram slots and alternated both sticks of ram. The 4 pin is connected to the MOBO from the PSU for the CPU. The CPU is placed correctly and so is the heat stink, I'm not using a graphics card. I ALSO DON'T HAVE AN HDD INSTALLED YET, WAITING FOR IT IN THE MAIL. (From what I've researched it should still post without a HDD.) List of parts here:
CPU: http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=8754568&tab=7&SRCCODE=WEBLET03ORDER&cm_mmc=Email-_-WebletMain-_-WEBLET03ORDER-_-Deals&utm_source=EML&utm_medium=main&utm_campaign=WEBLET03ORDER&cm_lm=joshkaylor91@gmail.com
Mobo: http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=8592788&tab=7&SRCCODE=WEBLET03ORDER&cm_mmc=Email-_-WebletMain-_-WEBLET03ORDER-_-Deals&utm_source=EML&utm_medium=main&utm_campaign=WEBLET03ORDER&cm_lm=joshkaylor91@gmail.com
PSU: http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=5079834&tab=7&SRCCODE=WEBLET03ORDER&cm_mmc=Email-_-WebletMain-_-WEBLET03ORDER-_-Deals&utm_source=EML&utm_medium=main&utm_campaign=WEBLET03ORDER&cm_lm=joshkaylor91@gmail.com
Ram: http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=7287860&tab=7&SRCCODE=WEBLET03ORDER&cm_mmc=Email-_-WebletMain-_-WEBLET03ORDER-_-Deals&utm_source=EML&utm_medium=main&utm_campaign=WEBLET03ORDER&cm_lm=joshkaylor91@gmail.com
Case: http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1636710&tab=7&SRCCODE=WEBLET03ORDER&cm_mmc=Email-_-WebletMain-_-WEBLET03ORDER-_-Deals&utm_source=EML&utm_medium=main&utm_campaign=WEBLET03ORDER&cm_lm=joshkaylor91@gmail.com
-Also I have already read the standard checklist sticky and have gone through all the precautions / checks thoroughly, still no post.
Thank you.
Thank you.
