Build
SSD : SAMSUNG 850 EVO 2.5" 250GB SATA III 3D NAND Internal Solid State Drive (SSD) MZ-75E250B/AM
PSU : EVGA 600 B1 100-B1-0600-KR 80+ BRONZE 600W Includes FREE Power On Self Tester Power Supply
CPU : AMD RYZEN 3 1200 4-Core 3.1 GHz (3.4 GHz Turbo) Socket AM4 65W YD1200BBAEBOX Desktop Processor
HDD : WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX - OEM
MOBO: ASRock X370 Taichi AM4 AMD Promontory X370 SATA 6Gb/s USB 3.1 ATX AMD Motherboard
DVD DRIVE: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
GPU: Nvidia 650 ti
RAM: G.SKILL Ripjaws V Series 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2400 (PC4 19200) Intel X299 / Z270 / Z170 / X99 ...
PROBLEM: Building my fiancee a PC for light gaming/photo editing and all that. Got everything together, hit power button and all the lights and fans will turn on. No beeps. The monitor won't turn on just displays the "No Signal R G B" and I can't power it down by holding down the power button or just pushing it. Reset button won't work either.
Things I've tried so far...
1. Rehousing the CPU, checked CPU - no bent pins
2. Made sure MOBO had proper spacing with spacers (it did)
3. Make sure everything was securely connected and the correct way (a lot of google help said "hurr make shure duh CPU connector is plugged in!")
4. Tried every variation I could with the two RAM sticks. One in one out, different connections.
5. Tried both PCI ports with video card.
6. Tried different PSU (both are working fine with good stable voltage)
7. GPU works (i put it back into my PC and am typing with it displaying the text right now)
8. Pulled and reinserted the MOBO battery CR2032
9. Cleared CMOS
10. This MOBO does not have an on board video card!
11. Ran the board outside of the case and still wont work.
just found this tidbit on Newegg
"B350 and X370 motherboards have compatibility issues with Ryzen processors and DDR4 memory. The issue is related to an AGESA update in the BIOS that is not shipped with some motherboards, preventing the unit from a successful POST."
wot m8
going to buy an Anthlon CPU tomorrow to see if it will POST and load the new BIOS then try the RIZEN. If you think it could be something else in the meantime please tell me!
I'm running out of ideas. Is the new MOBO dead and should I RMA it? Going to get a cheap compatible crap CPU from best buy to try and narrow that out tomorrow.
GPU: Nvidia 650 ti
9. Cleared CMOS
wot m8
