Specs
CPU: i5-9600k
Motherboard: Gigabyte Z390 Gaming X
RAM: 2 x 4GB DDR4 Corsair Vengeance LPX 3000MHz
Power supply: Corsair RM550x
GPU: MSI GTX 1060 6GB
SSD: Samsung 850 Evo 250GB
HDD: |Seggate barracuda 2TB 7200 rpm
CPU cooler: NZXT Kraken X52
Finally got around to upgrading my PC, finished building it this afternoon, POST was successful with no errors so didn't think I would have any issues (How very wrong I was).
When powering down the PC with the case button or the Windows button it does not properly shut down. All fans stay on, the pump stays on, GPU LEDs stay on, HDD case light still flashes, keyboard and mouse lights stay on however my monitor does turn off(go black, not detecting an input). Holding the case power button down (Force shutdown) does shut the system down fully though.
In addition to this, when the system is powered on and a USB device is plugged into any available port, it will not recognise it. However, if the device is plugged in when power is off and the system is started up it will recognise it and work fine.
I have tried updating the BIOS, looking for any strange BIOS settings, checking for any missing drivers and am currently doing a windows update. Is this a hardware or software issue, has anyone experienced anything like this before? I would seriously appreciate any advice as I'm pretty stumped at what is causing this issue. Other than the mentioned problems the system is running absolutely fine.
Thanks in advance.
CPU: i5-9600k
Thanks in advance.
