New build won't power up!
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
http://pcpartpicker.com/p/Ww2kHx
Here is my build, just pieced it together in PCPartPicker so you guys could see it. I powered it up and it brought me to the 'New CPU/Mobo' start up screen, so I turned it off and got it into place, plugged it all back up and now it won't work. Nothing was knocked/dropped, literally just shuffled to the side a little and the case put back on.
Opened it back up, no wires knocked out/dislodged - all is still solid. Any advice?
I managed to get it working, one of the pin-sockets was not going in properly. Straightened it out and it's working.
I know this PSU is a 38amp 12v and the GPU tops out at 42amp 12v. Will this cause too many issues? Should I upgrade the PSU soon anyway?
Could someone give me something better that I could replace it with, or will this be safe? Preferably not too much more than $60.
