[SOLVED] New Build won't power up
traepoint
8
I am building a new system. I have everything put together, but when trying to power up, the fans and LED lights turn on for a second then everything turns back off. I'm stuck. I have reseated all the connectors several times. The bios on the MB is version P 4.20. I have also removed the battery on the MB for a few minutes and that didnt seem to help.
  • WD Blue 4TB PC Hard Drive - 5400 RPM Class, SATA 6 Gb/s, 64 MB Cache, 3.5" - WD40EZRZ
  • Samsung 970 EVO 500GB - NVMe PCIe M.2 2280 SSD (MZ-V7E500BW)
  • Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15 Desktop Memory Kit - Black (CMK16GX4M2B3000C15)
  • ASRock B365M Phantom Gaming 4 LGA1151/ Intel B365/ DDR4/ Quad CrossFireX/ SATA3&USB3.1/ M.2/ A&GbE/MicroATX Motherboard
  • LG Super Multi Blue Internal SATA 16x Blu-ray Disc Rewriter OEM
  • Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply
  • Cooler Master RR-212E-20PK-R2 Hyper 212 EVO Processor Cooler
  • Intel - Core i7-9700K Octa-Core 3.6 GHz Desktop Processor
Ok. Wanted to check. Tried booting with single stick of RAM? Moving to different slots. Try disconnecting all hardware outside of bare minimum. Remove GPU and disconnect secondary HDD. This can help to narrow down the problem.
