New build won't stay on for more than 45 seconds.
chasertx
Commendable
Nov 27, 2016
6
So I just finished putting together my gaming rig and it will only stay on for 45seconds-1.5 minutes before shutting off and turning back on. any ideas?
yes make sure the cpu cooler and memory are attached correctly if you still have a problem I would disconnect every thing except for the CPU, Memory (only use 1 stick) and of course power. Plug the monitor into the the mother board (any external card should be removed) and see if you get a post screen.
So I pretty much disassembled the entire rig and reassembled it and the first time I turned it on, it did the same thing but then I tried one more time and it's fine now, Idk what changed or if I should be worried about issues in the future, what do you guys think?
