New builder needs help with motherboard compatibility
Sep 10, 2018
5
Hi all,
I recently purchased the Asus Prime B450M-A/CSM motherboard for my first pc build. To accompany this, I purchased the following items:
RAM: G.skill Fortis 16gb 2133mhz DDR4
SSD: Toshiba TR200 SSD (240gb)
HDD: Hitachi 2TB HDD
For reference, my CPU is an AMD Ryzen 2200G and my PSU is EVGA 450 BR.
However, after purchasing these products I realized that Asus had some QVLs that I didn't see before. I am now nervous that some of these storage/memory devices are incompatible with this motherboard. For instance, I do not even see Hitachi listed in the HDD section on the QVL PDF. Here is the link to the Asus website where you can see this: https://www.asus.com/us/Motherboards/PRIME-B450M-A-CSM/HelpDesk_QVL/
Please let me know if my hardware is compatible. It is all still within its return period so I should be able to switch things out if need be.
Thank you all so much in advance!
HDDs/SSDs are standard. They all work fine. The QVL list only has the units tested with the board. If its not there, doesnt mean it wont work.
But for optimum performance, make sure the HDD is a 7200rpm unit.
However, Ryzen's performance is directly related to RAM speed. And 2100mhz is not good for Ryzen performance. The optimum performance speed is around 3000/3200mhz. Return that if you can.
2133mhz may not be ideal, but is there any fundamental problem with using it? For instance, would it cause windows to crash (because I am having this problem)? I'm not a gamer so I don't push my computer too hard... also the CAS latency of the RAM is 15. RAM is super expensive and I'd rather not spend more money if I don't have to.
MERGED QUESTION
Question from agradone : "BSOD loop on Windows 10 clean install for new build"
It is at the lowest end of Ryzen performance. But, If you can sacrifice the performance delta, then it should be ok.
