New computer won’t turn on, HELP.
Jan 2, 2019
I have just built my computer but when I turned it on all fans and lights turned on for at most half a second then went out again. I then took it apart put it back togeather again multiple times but each time I had the same issue. I am confident that I have built it properly. I tested each component by removing them and trying again and trying different ones if possible but no luck.
I have ran through the troubleshoot guide that is already on the site and done it step by step.
Specs:
Core i7 4.0ghz 6700k lga1151
GTX 1050 2gb
2X8Gb Corsair vengeance ddr4
Gigabyte H110-D3A Lga 1151 mobo
EVGA 600w psu
1TB HDD
Kolink luminosity midi tower case
The only component I haven’t been able to test is the motherboard, without putting it in another PC how would I test it. Could it be a problem with the motherboard at all?
Would using my processor with the motherboard I have cause the computer to not turn on or is that just a suggestion? Additionally exactly is the problem with the RAM? By the way thank so much for the help.
