New CPU and Motherboard, no signal to monitor
TwistCone
7
I recently upgraded to an AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor and an Asus - PRIME X370-PRO ATX AM4 Motherboard. My build includes a corsair RM850 PSU, 16Gigs of DDR4 RAM, 120GB Kingston SSD, 120GB Samsung 840EVO, and a 1TB western Digital hard drive. When i turn on my comp everything turns on, fans work, no beeps. But my ASUS VG248QE 24" Full HD 1920x1080 monitor does not recieve a signal on HDMI from GPU or MoBo. Or DVI to GPU. Not sure what to do any advise will be helpful thank you.
You should double check all the power connectors to start with. It's easy to miss one when replacing a motherboard.
If they're all in place, connect the monitor to the GPU with HDMI, and then set the monitor's input to HDMI. This will ensure that it picks up anything that the GPU sends.
I have my PCI-E connectors in for the GPU, MoBo, and CPU. And I did what you said
Halp https://imgur.com/gallery/N6MFg
Yea i am missing a screw, but im using screws from an older mobo which i lost one screw so it no need to worry about that. Ill see if i can find another screw
The one in the center on the bottom right above the PSU, correct.
I tried unplugging everything but the hdmi from the gpu and io ports.
