Hi all,
I just installed a new CPU cooler, and speedfan is recording the same core temps, and somewhat higher temps from other readings.
First off, i'm not sure exactly what the first 4 temps are, so i'll post what they say here and hopefully somebody can help me out on that part.
Temp 1: 36C
Temp 2: 26C
Temp 3: -2C (???)
Temp 4: OC (umm)
Core 0: 41C
Core 1: 40C
Anyways, the processor I am using is an intel core2 duo E7400 running at stock clock speeds. I just recently got a Coolermaster V8 CPU cooler for my birthday, and installed it ASAP. The stock cooler temps used to look about the same, but temp 1 used to be running about 4C cooler. Anyways, the thermal paste I used was MX-2, made sure it was the perfect ammount and installed the cooler. Started her up and I'm sitting at about the same temps. Is 41/40C as cool as it will get? (ambient air temp is about 72degrees F) Or did i possibly mess something up? I'm using SpeedFan as my temprature reader.
Any information or help would be greatly appreciated.
Temp 1: 36C
Temp 2: 26C
Temp 3: -2C (???)
Temp 4: OC (umm)
Core 0: 41C
Core 1: 40C
