No output to Monitor After CPU Fan upgrade
Hi guys an issue i upgraded today my CPU from stock to Thermaltake fan.
The pc is a self build.
Runs a AMD fx8350
Mobo is asrock 970ex3
2 × 4gb corsair Ram
Gtx660 inno3d i think
Casecom cheap case with inbuilt PSU 500W
I know the psu sounds dodgy so bare with me.
Everything was working fine this morning. The stock CPU Cooler sounds like a jet engine so i went and baught a new one i did not take out the RAM or GPU nore the CPU all i did was take off stock cooler put the thermal gel on mind you probably to much of it and attach the new cooler.
Now everything seems to run fine when turning on. All fans run, LEDs and so on. There is no beep code either it just will not send a signal to my monitor which is 3 weeks old.
I have done the following.
Trying one RAM in each slot.
Re build the computer excluding cpu
Reset and jump CMOS
New monitor cords.
Runs a AMD fx8350
2 × 4gb corsair Ram
Reset and jump CMOS
New monitor cords.
