You really do not want to run the ram faster than 3600, as faster will cause latency, and worse performance. Is your bios up to date? Did you install the latest chipset and graphics drivers, from AMD? Did you do a fresh install of windows, when you upgraded?
Hey everyone, need some advice as to why my build isn't running as it should. The components are high end but when I run Fortnite, I get lower FPS than my old build and my game crashes way more than it should.
The power supply, storage, case, and graphics card are the same but I upgraded my motherboard, processor, and RAM.
Old build:
Intel i5-6600T processor
Asrock h110 pro btc+ motherboard
Asrock Radeon RX 6900XT OC Formula graphics card
Western Digital Blue 1 TB SSD
Western Digital Blue 2 TB HDD
RM 850x Power supply
Basic DDR4-2133 MHz RAM
New build:
Ryzen 9 3900x processor
MSI MPG X570 GAMING PLUS ATX AM4 Motherboard
2 Patriot Viper Steel (2x16GB) DDR4-4133 MHz RAM
Asus VG278QR 27.0" 1920x1080 165 Hz Monitor
I should be able to get a consistent 165 fps but sometimes it drops to 75 or high double digits.
Also - When I try to change my memory speed to the full 4133, my system doesn't boot. My system will only boot at a maximum 3600 speed.
Not sure if I provided enough details to figure out why my game crashes, or if I should provide more photos to help.
So below I am going to attach my full DxDiag results.. if anyone could help me understand why my game is still crashing with up to date drivers I would definitely be willing to paypal or venmo for support! Thank you all
System Information
Time of this report: 1/9/2022, 15:19:02
Machine name: DESKTOP-F8CELDP
Machine Id: {0F988F46-DBB7-46FC-857C-DC132EA8C5FF}
Operating System: Windows 10 Pro 64-bit (10.0, Build 19043) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: Micro-Star International Co., Ltd.
System Model: MS-7C37
BIOS: A.F0 (type: UEFI)
Processor: AMD Ryzen 9 3900X 12-Core Processor (24 CPUs), ~3.8GHz
Memory: 32768MB RAM
Available OS Memory: 32690MB RAM
Page File: 7898MB used, 48854MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.0928 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Sound Tab 5: No problems found.
Sound Tab 6: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon RX 6900 XT
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x73AF)
DAC type: Internal DAC(400MHz)
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_1002&DEV_73AF&SUBSYS_52131849&REV_C0
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 32683 MB
Dedicated Memory: 16338 MB
Shared Memory: 16344 MB
Current Mode: 1920 x 1080 (32 bit) (165Hz)
HDR Support: Not Supported
Display Topology: Extend
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.648438,0.332031), Green(0.325195,0.620117), Blue(0.155273,0.057617), White Point(0.312500,0.328125)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: VG278
Monitor Id: AUS2720
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: Displayport External
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\aticfx64.dll,C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\aticfx64.dll,C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\aticfx64.dll,C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdxc64.dll
Driver File Version: 30.00.13025.5005 (English)
Driver Version: 30.0.13025.5005
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: Supported:False Enabled:False
Graphics Preemption: Primitive
Compute Preemption: DMA
Miracast: Not Supported
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: DISABLE_HWSCH
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 10/4/2021 7:00:00 PM, 1837728 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71EE2-30EF-11CF-7468-F2406FC2D335}
Vendor ID: 0x1002
Device ID: 0x73AF
SubSys ID: 0x52131849
Revision ID: 0x00C0
Driver Strong Name: oem55.inf:cb0ae414275808ce:ati2mtag_Navi21:30.0.13025.5005
Rank Of Driver: 00CF0000
Video Accel: Unknown
DXVA2 Modes: DXVA2_ModeMPEG2_VLD {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeH264_VLD_NoFGT {4245F676-2BBC-4166-A0BB-54E7B849C380} {6719B6FB-5CAD-4ACB-B00A-F3BFDEC38727} {9901CCD3-CA12-4B7E-867A-E2223D9255C3} DXVA2_ModeHEVC_VLD_Main {EA72396A-67EC-4781-BEDE-56F498F04EF2} {C152CA8F-738C-461B-AD89-FC292CF8F162} {514A356C-7027-4AFF-8A60-AFD2C1F672F1} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeVC1_VLD {CA15D19A-2B48-43D6-979E-7A6E9C802FF8} {D1C20509-AE7B-4E72-AE3B-49F88D58992F} {84AD67F6-4C21-419A-9F0B-24F0578906C1} {725AD240-786C-471E-AD3C-38F739936517} {95664FF5-9E03-4C74-BB4F-9178D6035E58} {5EF7D40D-5B96-49E7-B419-23342094A4CF} DXVA2_ModeHEVC_VLD_Main10 {65D1FA41-58AF-453A-9CAB-5D981156DA9F} {2DB154B6-DBB2-4079-A3FF-60D7A898A6AB} {C74A3FD0-D713-4581-A02E-8EDFB112ACE3} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {B8BE4CCB-CF53-46BA-8D59-D6B8A6DA5D2A} {603A4756-A864-4F91-BB62-2C935B7A1391} {C58B9A06-7E89-11E1-BB00-70B34824019B}
Deinterlace Caps: n/a
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 2
MPO Caps: ROTATION,VERTICAL_FLIP,HORIZONTAL_FLIP,YUV,BILINEAR,STRETCH_YUV,HDR (MPO3)
MPO Stretch: 16.000X - 0.250X
MPO Media Hints: rotation, resizing, colorspace Conversion
MPO Formats: NV12,420_OPAQUE,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
PanelFitter Caps: ROTATION,VERTICAL_FLIP,HORIZONTAL_FLIP,YUV,BILINEAR,STRETCH_YUV,HDR (MPO3)
PanelFitter Stretch: 16.000X - 0.250X
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Color Primaries: Red(0.647461,0.333984), Green(0.284180,0.607422), Blue(0.151367,0.071289), White Point(0.312500,0.329102)
Monitor Model: 2476WM
Monitor Id: AOC2476
Output Type: HDMI
DDI Version: 12
Detachable GPU: No
WHQL Logo'd: Yes
Vendor ID: 0x1002
Device ID: 0x73AF
Revision ID: 0x00C0
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 2
Sound Devices
Description: 1 - VG278 (AMD High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1008
Manufacturer ID: N/A
Product ID: N/A
Type: N/A
Driver Name: AtihdWT6.sys
Driver Version: 10.0.1.21 (English)
WHQL Logo'd: Yes
Date and Size: 7/12/2021 7:00:00 PM, 246200 bytes
Other Files:
Driver Provider: Advanced Micro Devices
HW Accel Level: Emulation Only
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: 4 - 2476WM (AMD High Definition Audio Device)
Product ID: N/A
Type: N/A
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Digital Audio (S/PDIF) (2- High Definition Audio Device)
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_1168&SUBSYS_1462EC37&REV_1001
Product ID: N/A
Type: N/A
Driver Name: HdAudio.sys
Driver Version: 10.0.19041.264 (English)
WHQL Logo'd: Yes
Date and Size: 5/8/2020 7:00:00 PM, 430080 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (3- Razer Barracuda X)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_1532&PID_0536&REV_0100&MI_00
Product ID: N/A
Type: N/A
Driver Name: USBAUDIO.sys
Driver Version: 10.0.19041.1202 (English)
WHQL Logo'd: Yes
Date and Size: 8/25/2021 7:00:00 PM, 209920 bytes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (THX Spatial Audio)
Hardware ID: ROOT\THXV2VAD
Product ID: N/A
Type: N/A
Driver Name: THXVAD2.sys
Driver Version: 14.44.19.601 (English)
WHQL Logo'd: Yes
Date and Size: 5/31/2020 7:00:00 PM, 165776 bytes
Other Files:
Driver Provider: THX
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (THX Spatial)
Hardware ID: ROOT\RZTHXSpatial
Product ID: N/A
Type: N/A
Driver Name: RZTHXSpatial.sys
Driver Version: 21.13.12.850 (English)
WHQL Logo'd: Yes
Date and Size: 4/13/2020 7:00:00 PM, 172024 bytes
Other Files:
Driver Provider: Razer
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (3- Razer Barracuda X)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: HP USB Slim Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x03F0, 0x2F4A
FF Driver: n/a
Device Name: Multi-Device Keyboard K380
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xB342
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: 2.4G Wireless Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x062A, 0x4102
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Hid Interface
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x0536
FF Driver: n/a
Device Name: Controller (Xbox One For Windows)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x02FF
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x1022, 0x149C
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 10/6/2021 04:07:49, 648016 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 10/6/2021 04:07:49, 185664 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 10/6/2021 04:07:49, 44032 bytes
| | | Driver: hidclass.sys, 10/6/2021 04:07:49, 225792 bytes
| | | Driver: hidparse.sys, 10/6/2021 04:07:49, 46080 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 12/7/2019 04:07:56, 46592 bytes
| | | | Driver: kbdclass.sys, 12/7/2019 04:07:56, 71480 bytes
| Service: USBHUB3
| | Service: HidUsb
| +-+ HID-compliant mouse
| | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | Service: mouhid
| | | Driver: mouhid.sys, 12/7/2019 04:07:56, 35328 bytes
| | | Driver: mouclass.sys, 12/7/2019 04:07:56, 67600 bytes
+-+ Generic Bluetooth Radio
| | Vendor/Product ID: 0x0A12, 0x0001
| | Matching Device ID: USB\VID_0A12&PID_0001
| | Service: BTHUSB
| | Driver: BTHUSB.SYS, 12/15/2021 02:14:17, 110592 bytes
| | Driver: bthport.sys, 12/15/2021 02:14:17, 1559552 bytes
| +-+ Microsoft Bluetooth Enumerator
| | | Matching Device ID: BTH\MS_BTHBRB
| | | Service: BthEnum
| | | Driver: bthenum.sys, 12/15/2021 02:14:17, 113664 bytes
| | +-+ Bluetooth HID Device
| | | | Vendor/Product ID: 0x0000, 0x0B34
| | | | Matching Device ID: BTHENUM\{00001124-0000-1000-8000-00805f9b34fb}
| | | | Service: HidBth
| | | | Driver: hidbth.sys, 10/6/2021 04:07:49, 120320 bytes
| | | | | Service: kbdhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 799.2 GB
Total Space: 953.2 GB
File System: NTFS
Model: WDC WDBNCE0010PNC
Drive: D:
Free Space: 625.4 GB
Total Space: 635.9 GB
File System: NTFS
Model: WDC WD20EZAZ-00L9GB0
Drive: E:
Free Space: 630.1 GB
File System: NTFS
Drive: R:
Free Space: 557.6 GB
File System: NTFS
System Devices
Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_1022&DEV_7901&SUBSYS_79011022&REV_51\6&7D521C4&0&0048000A
Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.19041.1288 (English), 10/6/2021 04:07:49, 186168 bytes
Name: AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)
Device ID: PCI\VEN_1022&DEV_149C&SUBSYS_7C371462&REV_00\4&1FDE7688&0&0341
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.19041.1320 (English), 11/12/2021 12:19:41, 629072 bytes
Driver: C:\Windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.19041.1320 (English), 11/12/2021 12:19:41, 137944 bytes
Device ID: PCI\VEN_1022&DEV_1483&SUBSYS_14531022&REV_00\3&11583659&0&0A
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.19041.1387 (English), 12/15/2021 02:14:17, 469840 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1447&SUBSYS_00000000&REV_00\3&11583659&0&C7
Driver: n/a
Name: Realtek PCIe GbE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_7C371462&REV_15\6&1AEFE097&0&0028000A
Driver: C:\Windows\system32\DRIVERS\rt640x64.sys, 9.01.0410.2015 (English), 12/7/2019 04:07:54, 694272 bytes
Device ID: PCI\VEN_1B21&DEV_0612&SUBSYS_10601B21&REV_02\6&B8B3ABA&0&0020000A
Device ID: PCI\VEN_1022&DEV_1485&SUBSYS_14851022&REV_00\6&1EA5F98D&0&0040000A
Driver: C:\Windows\system32\DRIVERS\AMDPCIDev.sys, 1.00.0000.0083 (English), 6/18/2021 08:31:56, 41184 bytes
Name: AMD PCI Express Upstream Switch Port
Device ID: PCI\VEN_1002&DEV_1478&SUBSYS_00000000&REV_C0\6&2E475EF&0&0030000A
Device ID: PCI\VEN_1022&DEV_1442&SUBSYS_00000000&REV_00\3&11583659&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_149C&SUBSYS_148C1022&REV_00\6&1EA5F98D&0&0340000A
Device ID: PCI\VEN_1022&DEV_1445&SUBSYS_00000000&REV_00\3&11583659&0&C5
Driver: n/a
Device ID: PCI\VEN_1022&DEV_790B&SUBSYS_7C371462&REV_61\3&11583659&0&A0
Driver: n/a
Name: High Definition Audio Bus
Device ID: PCI\VEN_1002&DEV_AB28&SUBSYS_AB281002&REV_00\8&3B96CF8D&0&01000030000A
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.19041.1081 (English), 10/6/2021 04:07:48, 139776 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.19041.0746 (English), 10/6/2021 04:07:48, 97792 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.19041.0746 (English), 10/6/2021 04:07:48, 388608 bytes
Device ID: PCI\VEN_1022&DEV_1485&SUBSYS_14851022&REV_00\4&1FDE7688&0&0041
Device ID: PCI\VEN_1022&DEV_1480&SUBSYS_7C371462&REV_00\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_1022&DEV_57A3&SUBSYS_14531022&REV_00\5&2FFEF63F&0&28000A
Name: High Definition Audio Controller
Device ID: PCI\VEN_1022&DEV_1487&SUBSYS_EC371462&REV_00\4&1FDE7688&0&0441
Device ID: PCI\VEN_1022&DEV_57A3&SUBSYS_14531022&REV_00\5&2FFEF63F&0&30000A
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1022&DEV_790E&SUBSYS_7C371462&REV_51\3&11583659&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.19041.1202 (English), 10/6/2021 04:07:49, 20280 bytes
Device ID: PCI\VEN_1022&DEV_57A4&SUBSYS_14841022&REV_00\5&2FFEF63F&0&48000A
Device ID: PCI\VEN_1022&DEV_1440&SUBSYS_00000000&REV_00\3&11583659&0&C0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_57A4&SUBSYS_14841022&REV_00\5&2FFEF63F&0&50000A
Device ID: PCI\VEN_1022&DEV_57A3&SUBSYS_14531022&REV_00\5&2FFEF63F&0&20000A
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&40
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&38
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&28
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&20
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&18
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&10
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&08
Driver: n/a
Device ID: PCI\VEN_1022&DEV_57A4&SUBSYS_14841022&REV_00\5&2FFEF63F&0&40000A
Device ID: PCI\VEN_1022&DEV_1443&SUBSYS_00000000&REV_00\3&11583659&0&C3
Driver: n/a
Name: AMD Radeon RX 6900 XT
Device ID: PCI\VEN_1002&DEV_73AF&SUBSYS_52131849&REV_C0\8&3B96CF8D&0&00000030000A
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_vcn3.dat, 12/28/2021 19:54:58, 540800 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_vcn3_1.dat, 12/28/2021 19:54:58, 525888 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\aticfx32.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:20, 1506880 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\aticfx64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:22, 1837728 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiumdag.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:46, 11361048 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiumdva.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:50, 14064280 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiumd64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:40, 14131568 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiumd6a.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:44, 14986104 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativce02.dat, 12/28/2021 19:54:58, 100832 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_cik.dat, 12/28/2021 19:54:58, 234676 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_cik_nd.dat, 12/28/2021 19:54:58, 234416 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdmmcl.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:22, 126840 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdmmcl6.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:24, 148848 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_nv.dat, 12/28/2021 19:54:58, 398016 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdefctb.dat, 12/28/2021 19:54:46, 515240 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdxn32.dll, 8.14.0010.0158 (English), 12/28/2021 20:18:38, 27216224 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdxn64.dll, 8.14.0010.0158 (English), 12/28/2021 20:18:40, 32224112 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_vg20.dat, 12/28/2021 19:54:58, 379200 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_vg20_nd.dat, 12/28/2021 19:54:58, 383392 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdave32.dll, 30.00.13025.5005 (English), 12/28/2021 20:17:52, 134752 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdave64.dll, 30.00.13025.5005 (English), 12/28/2021 20:17:54, 159472 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_rv.dat, 12/28/2021 19:54:58, 362976 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amde40a.dat, 12/28/2021 19:54:46, 173536 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_gl_nd.dat, 12/28/2021 19:54:58, 380576 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amduve64.dll, 18.03.0006.0000 (English), 12/28/2021 20:18:10, 199680 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amduve32.dll, 18.03.0006.0000 (English), 12/28/2021 20:18:10, 166048 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amfrtdrv32.dll, 1.04.0022.0000 (English), 12/28/2021 20:18:50, 5731704 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amfrtdrv64.dll, 1.04.0022.0000 (English), 12/28/2021 20:18:50, 6052704 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\AMDh265Enc32.dll, 30.00.13025.5005 (English), 12/28/2021 20:17:58, 1275984 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\AMDh265Enc64.dll, 30.00.13025.5005 (English), 12/28/2021 20:17:58, 1615728 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ccc2_install.exe, 8.911.0003.3000 (English), 12/28/2021 20:19:28, 197332928 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amde34b.dat, 12/28/2021 19:54:46, 175008 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amde34a.dat, 12/28/2021 19:54:46, 175008 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_stn_nd.dat, 12/28/2021 19:54:58, 278432 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdvlk32.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:32, 40710504 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdvlk64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:34, 46631800 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amd-vulkan32.json, 12/28/2021 19:54:46, 703 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amd-vulkan64.json, 12/28/2021 19:54:46, 703 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_el_nd.dat, 12/28/2021 19:54:58, 376224 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdicdxx.dat, 12/28/2021 19:54:46, 1230676 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiicdxx.dat, 12/28/2021 19:54:56, 737410 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_FJ.dat, 12/28/2021 19:54:58, 268244 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_FJ_nd.dat, 12/28/2021 19:54:58, 267984 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdxc32.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:14, 41012504 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdxc64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:16, 46601424 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_cz_nd.dat, 12/28/2021 19:54:58, 272928 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amde31a.dat, 12/28/2021 19:54:46, 159072 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\AMDhwDecoder_32.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:10, 247160 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\AMDhwDecoder_64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:10, 300424 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\AMDh264Enc32.dll, 30.00.13025.5005 (English), 12/28/2021 20:17:54, 1969920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\AMDh264Enc64.dll, 30.00.13025.5005 (English), 12/28/2021 20:17:56, 2106712 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativce03.dat, 12/28/2021 19:54:58, 160768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_vi.dat, 12/28/2021 19:54:58, 325188 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\ativvaxy_vi_nd.dat, 12/28/2021 19:54:58, 324928 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdhdl32.dll, 12/28/2021 20:18:00, 396496 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdhdl64.dll, 12/28/2021 20:18:02, 521936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdocl.dll, 10.00.3302.0006 (English), 12/28/2021 20:18:26, 58764648 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdocl64.dll, 10.00.3302.0006 (English), 12/28/2021 20:18:28, 69191528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdmantle32.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:20, 27512696 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdmantle64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:22, 32478584 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiesrxx.exe, 30.00.13025.5005 (English), 12/28/2021 20:19:10, 595872 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiu9pag.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:38, 181968 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atigktxx.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:16, 220064 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiglpxx.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:16, 152480 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiuxpag.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:54, 201800 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiu9p64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:36, 222872 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atiuxp64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:52, 240240 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atig6pxx.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:12, 181160 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atig6txx.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:14, 261024 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atidxx32.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:26, 27820384 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atidxx64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:32, 33227752 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atioglxx.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:22, 38780848 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\atio6axx.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:20, 47603608 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdkmdag.sys, 30.00.13025.5005 (English), 12/28/2021 20:18:16, 80510840 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdenc64.dll, 0.00.0000.0000 (English), 12/28/2021 20:18:02, 457416 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\u0375241.inf_amd64_d44db39d92abc6bc\B372333\amdenc32.dll, 0.00.0000.0000 (English), 12/28/2021 20:18:00, 349760 bytes
Driver: C:\Windows\system32\aticfx64.dll, 8.17.0010.1697 (English), 12/28/2021 20:19:00, 202512 bytes
Driver: C:\Windows\system32\atisamu64.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:26, 179104 bytes
Driver: C:\Windows\system32\atiumd6a.cap, 12/28/2021 19:54:56, 3437632 bytes
Driver: C:\Windows\system32\ativvsva.dat, 10/13/2021 22:01:36, 157144 bytes
Driver: C:\Windows\system32\ativvsvl.dat, 10/13/2021 22:01:36, 204952 bytes
Driver: C:\Windows\system32\atimpc64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:36, 149040 bytes
Driver: C:\Windows\system32\atimuixx.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:18, 167328 bytes
Driver: C:\Windows\system32\amdihk64.dll, 2.00.0000.1788 (English), 12/28/2021 20:18:14, 210696 bytes
Driver: C:\Windows\system32\amd_comgr.dll, 12/28/2021 20:18:40, 84045688 bytes
Driver: C:\Windows\system32\amdlogum.exe, 12/28/2021 20:18:18, 466296 bytes
Driver: C:\Windows\system32\amdhip64.dll, 10.00.3302.0006 (English), 12/28/2021 20:18:08, 69808520 bytes
Driver: C:\Windows\system32\EEURestart.exe, 12/28/2021 20:19:36, 490872 bytes
Driver: C:\Windows\system32\atiadlxx.dll, 30.00.14011.3017 (English), 12/1/2021 20:50:14, 1858600 bytes
Driver: C:\Windows\system32\amdave64.dll, 30.00.13025.5005 (English), 12/28/2021 20:17:54, 159472 bytes
Driver: C:\Windows\system32\amdpcom64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:06, 149056 bytes
Driver: C:\Windows\system32\amfrt64.dll, 1.04.0023.0000 (English), 12/1/2021 20:50:08, 129576 bytes
Driver: C:\Windows\system32\dgtrayicon.exe, 12/28/2021 20:19:36, 501152 bytes
Driver: C:\Windows\system32\AMDKernelEvents.man, 10/13/2021 22:01:16, 76237 bytes
Driver: C:\Windows\system32\vulkan-1.dll, 1.02.0189.0002 (English), 12/1/2021 20:51:06, 1116480 bytes
Driver: C:\Windows\system32\vulkan-1-999-0-0-0.dll, 1.02.0189.0002 (English), 12/1/2021 20:51:06, 1116480 bytes
Driver: C:\Windows\system32\vulkaninfo.exe, 1.02.0189.0002 (English), 12/1/2021 20:51:08, 1875496 bytes
Driver: C:\Windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.02.0189.0002 (English), 12/1/2021 20:51:08, 1875496 bytes
Driver: C:\Windows\system32\GameManager64.dll, 12/28/2021 20:19:38, 556936 bytes
Driver: C:\Windows\system32\amdmiracast.dll, 12/28/2021 20:18:02, 548304 bytes
Driver: C:\Windows\system32\amdlvr64.dll, 1.00.0016.0000 (English), 12/28/2021 20:18:20, 941432 bytes
Driver: C:\Windows\system32\RapidFireServer64.dll, 1.02.0000.0015 (English), 12/28/2021 20:19:50, 46456 bytes
Driver: C:\Windows\system32\Rapidfire64.dll, 2.01.0000.0020 (English), 12/28/2021 20:19:48, 796552 bytes
Driver: C:\Windows\system32\amdxc64.dll, 8.18.0010.0427 (English), 12/28/2021 20:18:36, 132976 bytes
Driver: C:\Windows\system32\amf-mft-mjpeg-decoder64.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:18, 1712160 bytes
Driver: C:\Windows\system32\mcl64.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:46, 91560 bytes
Driver: C:\Windows\system32\kapp_ci.sbin, 10/13/2021 22:01:38, 128048 bytes
Driver: C:\Windows\system32\samu_krnl_ci.sbin, 10/13/2021 22:01:38, 154384 bytes
Driver: C:\Windows\system32\samu_krnl_isv_ci.sbin, 10/13/2021 22:01:38, 138832 bytes
Driver: C:\Windows\system32\kapp_si.sbin, 10/13/2021 22:01:38, 121168 bytes
Driver: C:\Windows\system32\OpenCL.dll, 2.02.0006.0000 (English), 12/28/2021 20:18:46, 149872 bytes
Driver: C:\Windows\system32\clinfo.exe, 12/28/2021 20:19:30, 344480 bytes
Driver: C:\Windows\system32\mantle64.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:40, 201096 bytes
Driver: C:\Windows\system32\mantleaxl64.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:44, 180600 bytes
Driver: C:\Windows\system32\detoured.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:34, 28992 bytes
Driver: C:\Windows\system32\amdgfxinfo64.dll, 12/28/2021 20:18:06, 556936 bytes
Driver: C:\Windows\system32\atieah64.exe, 12/28/2021 20:19:08, 525216 bytes
Driver: C:\Windows\system32\atieclxx.exe, 30.00.13025.5005 (English), 12/28/2021 20:19:10, 848800 bytes
Driver: C:\Windows\system32\atiapfxx.blb, 12/28/2021 19:54:52, 562656 bytes
Driver: C:\Windows\system32\atig6txx.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:14, 261024 bytes
Driver: C:\Windows\system32\atidxx64.dll, 12/28/2021 20:19:06, 139680 bytes
Driver: C:\Windows\system32\ati2erec.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:52, 70008 bytes
Driver: C:\Windows\system32\atidemgy.dll, 4.05.7948.20461 (English), 12/28/2021 20:19:02, 469408 bytes
Driver: C:\Windows\system32\amdxc64.so, 12/28/2021 19:54:50, 58447000 bytes
Driver: C:\Windows\system32\atiacm64.dll, 6.14.0010.2001 (English), 12/28/2021 20:18:54, 1536352 bytes
Driver: C:\Windows\system32\atiacmLocalisation.ini, 12/28/2021 19:54:52, 11014 bytes
Driver: C:\Windows\system32\branding.bmp, 10/13/2021 22:01:36, 822 bytes
Driver: C:\Windows\system32\brandingRSX.bmp, 10/13/2021 22:01:36, 12344 bytes
Driver: C:\Windows\system32\brandingWS_RSX.bmp, 10/13/2021 22:01:36, 12344 bytes
Driver: C:\Windows\SysWOW64\aticfx32.dll, 8.17.0010.1697 (English), 12/28/2021 20:19:00, 165368 bytes
Driver: C:\Windows\SysWOW64\atisamu32.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:24, 141728 bytes
Driver: C:\Windows\SysWOW64\atiumdva.cap, 12/28/2021 19:54:56, 3471376 bytes
Driver: C:\Windows\SysWOW64\ativvsva.dat, 10/13/2021 22:01:36, 157144 bytes
Driver: C:\Windows\SysWOW64\ativvsvl.dat, 10/13/2021 22:01:36, 204952 bytes
Driver: C:\Windows\SysWOW64\atimpc32.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:34, 120112 bytes
Driver: C:\Windows\SysWOW64\amdihk32.dll, 2.00.0000.1788 (English), 12/28/2021 20:18:12, 178248 bytes
Driver: C:\Windows\SysWOW64\amd_comgr32.dll, 12/28/2021 20:18:42, 69093744 bytes
Driver: C:\Windows\SysWOW64\atiadlxx.dll, 30.00.14011.3017 (English), 12/1/2021 20:50:16, 1395752 bytes
Driver: C:\Windows\SysWOW64\atiadlxy.dll, 30.00.14011.3017 (English), 12/1/2021 20:50:16, 1395752 bytes
Driver: C:\Windows\SysWOW64\amdave32.dll, 30.00.13025.5005 (English), 12/28/2021 20:17:52, 134752 bytes
Driver: C:\Windows\SysWOW64\amdpcom32.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:06, 120112 bytes
Driver: C:\Windows\SysWOW64\amfrt32.dll, 1.04.0023.0000 (English), 12/1/2021 20:50:08, 105512 bytes
Driver: C:\Windows\SysWOW64\vulkan-1.dll, 1.02.0189.0002 (English), 12/1/2021 20:51:04, 969648 bytes
Driver: C:\Windows\SysWOW64\vulkan-1-999-0-0-0.dll, 1.02.0189.0002 (English), 12/1/2021 20:51:04, 969648 bytes
Driver: C:\Windows\SysWOW64\vulkaninfo.exe, 1.02.0189.0002 (English), 12/1/2021 20:51:06, 1451608 bytes
Driver: C:\Windows\SysWOW64\vulkaninfo-1-999-0-0-0.exe, 1.02.0189.0002 (English), 12/1/2021 20:51:06, 1451608 bytes
Driver: C:\Windows\SysWOW64\GameManager32.dll, 12/28/2021 20:19:38, 418168 bytes
Driver: C:\Windows\SysWOW64\amdlvr32.dll, 1.00.0016.0000 (English), 12/28/2021 20:18:18, 768888 bytes
Driver: C:\Windows\SysWOW64\RapidFireServer.dll, 1.02.0000.0015 (English), 12/28/2021 20:19:50, 43384 bytes
Driver: C:\Windows\SysWOW64\Rapidfire.dll, 2.01.0000.0020 (English), 12/28/2021 20:19:48, 673664 bytes
Driver: C:\Windows\SysWOW64\amdxc32.dll, 8.18.0010.0427 (English), 12/28/2021 20:18:34, 109416 bytes
Driver: C:\Windows\SysWOW64\amf-mft-mjpeg-decoder32.dll, 30.00.13025.5005 (English), 12/28/2021 20:18:18, 1388160 bytes
Driver: C:\Windows\SysWOW64\mcl32.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:44, 76192 bytes
Driver: C:\Windows\SysWOW64\OpenCL.dll, 2.02.0006.0000 (English), 12/28/2021 20:18:44, 130936 bytes
Driver: C:\Windows\SysWOW64\mantle32.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:40, 157560 bytes
Driver: C:\Windows\SysWOW64\mantleaxl32.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:42, 142200 bytes
Driver: C:\Windows\SysWOW64\detoured.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:32, 29008 bytes
Driver: C:\Windows\SysWOW64\amdgfxinfo32.dll, 12/28/2021 20:18:02, 420216 bytes
Driver: C:\Windows\SysWOW64\atieah32.exe, 12/28/2021 20:19:06, 393632 bytes
Driver: C:\Windows\SysWOW64\atiapfxx.blb, 12/28/2021 19:54:52, 562656 bytes
Driver: C:\Windows\SysWOW64\atigktxx.dll, 30.00.13025.5005 (English), 12/28/2021 20:19:16, 220064 bytes
Driver: C:\Windows\SysWOW64\atidxx32.dll, 12/28/2021 20:19:04, 113560 bytes
Driver: C:\Windows\system32\AMD\amdkmpfd\amdkmpfd.stz, 21.40.0001.0000 (English), 12/28/2021 20:18:16, 117512 bytes
Driver: C:\Windows\system32\AMD\amdkmpfd\amdkmpfd.itz, 10/13/2021 22:01:16, 1999 bytes
Driver: C:\Windows\system32\AMD\amdkmpfd\amdkmpfd.ctz, 10/13/2021 22:01:16, 10100 bytes
Device ID: PCI\VEN_1022&DEV_1446&SUBSYS_00000000&REV_00\3&11583659&0&C6
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_14841022&REV_00\3&11583659&0&41
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_14841022&REV_00\3&11583659&0&39
Device ID: PCI\VEN_1022&DEV_7901&SUBSYS_79011022&REV_51\6&2B648123&0&0050000A
Device ID: PCI\VEN_1022&DEV_148A&SUBSYS_148A1022&REV_00\4&D573D7&0&0039
Device ID: PCI\VEN_1022&DEV_1441&SUBSYS_00000000&REV_00\3&11583659&0&C1
Driver: n/a
Name: AMD PCI Express Downstream Switch Port
Device ID: PCI\VEN_1002&DEV_1479&SUBSYS_14791002&REV_00\7&25A77090&0&000030000A
Device ID: PCI\VEN_1022&DEV_149C&SUBSYS_14861022&REV_00\6&1EA5F98D&0&0140000A
Device ID: PCI\VEN_1022&DEV_57AD&SUBSYS_00000000&REV_00\4&5F22ECF&0&000A
Device ID: PCI\VEN_1022&DEV_1444&SUBSYS_00000000&REV_00\3&11583659&0&C4
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.19041.1288
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.19041.1288
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.19041.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.19041.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.19041.0450
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.19041.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.19041.1110
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.19041.1165
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.19041.1165
DV Muxer,0x00400000,0,0,qdv.dll,10.00.19041.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.19041.0746
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.19041.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.19041.0746
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.19041.0746
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.19041.1320
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.19041.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.19041.0746
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.19041.0746
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.19041.0329
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.19041.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.19041.0746
DV Splitter,0x00600000,1,2,qdv.dll,10.00.19041.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.19041.0746
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.19041.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.19041.0746
Video Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.19041.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.19041.0746
Video Renderer,0x00400000,1,0,quartz.dll,10.00.19041.0746
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.19041.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.19041.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.19041.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.19041.0746
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.19041.0746
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.19041.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.19041.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.19041.0746
Null Renderer,0x00200000,1,0,qedit.dll,10.00.19041.0746
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.19041.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.19041.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.19041.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.19041.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.19041.0746
Wave Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
File stream renderer,0x00400000,1,1,quartz.dll,10.00.19041.0746
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.19041.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.19041.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.19041.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.19041.0746
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.19041.0746
File Source (URL),0x00400000,0,1,quartz.dll,10.00.19041.0746
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.19041.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.19041.0546
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.19041.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.19041.0746
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.19041.0867
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.19041.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.19041.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.19041.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.19041.0746
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.19041.0508
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.19041.0508
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.19041.0746
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.19041.0746
Audio Capture Sources:
Microphone (3- Razer Barracuda X),0x00200000,0,0,qcap.dll,10.00.19041.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.19041.1266
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.1266
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.1266
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.19041.0746
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
Razer Barracuda X,0x00200000,2,2,ksproxy.ax,10.00.19041.0746
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
,0x00200000,1,1,,
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
,0x00000000,0,0,,
AMD HD Audio HDMI out #3,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
AMD HD Audio DP out #0,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
THX Spatial Wave Speaker Headphone,0x00200000,2,2,ksproxy.ax,10.00.19041.0746
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.19041.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.19041.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.19041.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (3- Razer Barracuda X),0x00200000,1,0,quartz.dll,10.00.19041.0746
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: Speakers (3- Razer Barracuda X),0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: 4 - 2476WM (AMD High Definition Audio Device),0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: Digital Audio (S/PDIF) (2- High Definition Audio Device),0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: Speakers (THX Spatial),0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: 1 - VG278 (AMD High Definition Audio Device),0x00200000,1,0,quartz.dll,10.00.19041.0746
DirectSound: Speakers (THX Spatial Audio),0x00200000,1,0,quartz.dll,10.00.19041.0746
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.19041.1415
mfreadwrite.dll, 10.00.19041.0746
mfcaptureengine.dll, 10.00.19041.0906
mfsensorgroup.dll, 10.00.19041.1266
windows.media.dll, 10.00.19041.1387
frameserver.dll, 10.00.19041.1266
frameserverclient.dll, 10.00.19041.1266
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
Intel® Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 10.20.0007.0015
AMD D3D11 Hardware MFT Playback Decoder, {17796AEB-0F66-4663-B8FB-99CBEE0224CE}, 0x4, 8, amdhwdecoder_64.dll, 30.00.13025.5005
AMD MFT MJPEG Decoder, {687CBC51-25DA-4FFC-A678-1E64943285A7}, 0x4, 8, amf-mft-mjpeg-decoder64.dll, 30.00.13025.5005
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpegx.dll, 30.00.0014.9709
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.19041.1320
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.19041.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.19041.0450
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.19041.1320
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.19041.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.19041.1110
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.19041.1348
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.19041.1165
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.19041.1165
VP9VideoExtensionDecoder
WebpImageExtension
HEIFImageExtension
Video Encoders:
Intel® Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 10.20.0007.0015
AMDh265Encoder, {5FD65104-A924-4835-AB71-09A223E3E37B}, 0x4, 8, amdh265enc64.dll, 30.00.13025.5005
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264x.dll, 30.00.0014.9709
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevcx.dll, 30.00.0014.9709
AMDh264Encoder, {ADC9BC80-0F41-46C6-AB75-D693D793597D}, 0x4, 8, amdh264enc64.dll, 30.00.13025.5005
Intel® Hardware H265 Encoder MFT, {BC10864D-2B34-408F-912A-102B1B867B6C}, 0x4, 7, mfx_mft_h265ve_64.dll, 10.20.0007.0015
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.19041.0964
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.19041.0867
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.19041.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.19041.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.19041.0001
VP9VideoExtensionEncoder
HEIFImageExtension
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.19041.0867
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.19041.0746
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.19041.1110
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.19041.1387
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.19041.1415
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.19041.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.19041.1288
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.19041.1165
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.19041.1415
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.19041.1415
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.19041.1288
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.19041.0746
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.19041.1320
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.19041.1165
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.19041.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.19041.1415
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.19041.1415
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.19041.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.19041.0746
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.19041.1415
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.19041.1415
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.19041.0746
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.19041.0508
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.19041.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.19041.0001
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.19041.0508
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.19041.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.19041.0746
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.19041.0001
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.19041.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.19041.0001
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.19041.1266
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.19041.1320
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 1457677423753423832, type 4
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: dwm.exe
P2: 10.0.19041.746
P3: 6be51595
P4: ism.dll
P5: 10.0.19041.1415
P6: b719d7f3
P7: c0000005
P8: 0000000000088c1a
P9:
P10:
+++ WER1 +++:
Cab Id: 0
Problem signature:
P1: dwm.exe
P2: 10.0.19041.746
P3: 6be51595
P4: ism.dll
P5: 10.0.19041.1415
P6: b719d7f3
P7: c0000005
P9:
P10:
+++ WER2 +++:
Cab Id: 0
Problem signature:
P1: dwm.exe
P2: 10.0.19041.746
P3: 6be51595
P4: ism.dll
P5: 10.0.19041.1415
P6: b719d7f3
P7: c0000005
P9:
P10:
+++ WER3 +++:
Fault bucket 1245203521004586564, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Problem signature:
P1: teamredminer.exe
P2: 1.0.0.0
P3: 10.0.19043.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: dwm.exe
P2: 10.0.19041.746
P3: 6be51595
P4: ism.dll
P5: 10.0.19041.1415
P6: b719d7f3
P7: c0000005
P9:
P10:
+++ WER5 +++:
Cab Id: 0
Problem signature:
P1: dwm.exe
P2: 10.0.19041.746
P3: 6be51595
P4: ism.dll
P5: 10.0.19041.1415
P6: b719d7f3
P7: c0000005
P9:
P10:
+++ WER6 +++:
Fault bucket 1249911064482625042, type 4
Cab Id: 0
Problem signature:
P1: svchost.exe_BcastDVRUserService
P2: 10.0.19041.546
P3: 058e175a
P4: atidxx64.dll
P5: 30.0.13025.5005
P6: 615c6ed3
P7: c0000005
P8: 00000000000966d4
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: dwm.exe
P2: 10.0.19041.746
P3: 6be51595
P4: ism.dll
P5: 10.0.19041.1415
P6: b719d7f3
P7: c0000005
P9:
P10:
+++ WER8 +++:
Cab Id: 0
Problem signature:
P1: dwm.exe
P2: 10.0.19041.746
P3: 6be51595
P4: ism.dll
P5: 10.0.19041.1415
P6: b719d7f3
P7: c0000005
P9:
P10:
+++ WER9 +++:
Cab Id: 0
Problem signature:
P1: dwm.exe
P2: 10.0.19041.746
P3: 6be51595
P4: ism.dll
P5: 10.0.19041.1415
P6: b719d7f3
P7: c0000005
P9:
P10:
