New Gaming PC [$ 1500][Will order parts this week}
avinash1234
25
i will start to buy the parts this week
i am fixed on
CPU
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop
SSD
Crucial m4 128 GB already bought
HARD DISK
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB
RAM
Mushkin Enhanced Blackline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
need suggestion on the following
MOBO was thinking of taking the MSI z68 board but new gen 3 boards have come so i need some suggestion there.
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
this is cheaper but has only 2 sata 6 GBps ports and only 1 year warranty
or
MSI Z68A-GD65 (G3) LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130611
this is costly but has 4 SATA 6 GBPS ports and 3 years warranty i like the MSI board what do you guys suggest.
CPU CASE
Rosewill BLACKHAWK Gaming ATX Mid Tower Computer Case, come with Five Fans, window side panel, top HDD dock
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
or
Rosewill THOR V2 Gaming ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
or a bit pricey one
Corsair 600T
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139007
or suggest any other good case with ventilation within 100-120 dollars
GPU
EVGA DS Superclocked 015-P3-1587-AR GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 $465 with promo code
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130658
lifetime warranty
or any other card you guys suggest
PSU need to be sli ready just in case i plan on sli with 580
LEPA G900-MA 900W SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular
http://www.newegg.com/Product/Product.aspx?Item=N82E16817194083
or
CORSAIR Professional Series HX850 (CMPSU-850HX) 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
Monitor
i am planning on getting the hpzr24w if anybody already owns this monitor please let me know if its good for gaming.
please suggest me anything u guys think is inappropriate and let me know of any good combos.
Thanks guys for all the help till now
I like that LEPA and Asrock, but you can't really go wrong with any of the choices you listed.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.707851 $199.98 - $10.00 Mail In Rebates
Corsair Graphite Series 600T CC600TM Mid-Tower Gaming Case
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Black heat spreaders on that RAM just like on the Mushkin.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.694806 $264.98 FREE SHIPPING
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model...
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model CML8GX3M2A1600C9
thanks for the combo links ...i had one more doubt usually when i buy anything from newegg they send the coupons the next day should i order one part and wait for the coupons or directly talk to them what i am going to purchase and see if they can provide the coupons in advance.
i was looking for any reviews of the monitor for gaming do you know anything about the monitor hpzr24w
http://www.amazon.com/HP-ZR24w-24-inch-S-IPS-Monitor/dp/B003D1ADUU <---- If that's the one your talking about...IPS is good for viewing angles and clarity, but they suck for gaming for the fact IPS panels have slow response time and that usually leads to ghosting in regards to gaming. That monitor in the link has a 7ms response time which is super slow for a gaming monitor.
I would look for a monitor with 5ms at the highest even though most gaming monitors have a 2ms response time.
just looked at newegg page lepa has three years but i think i will go with your choice
do you have any idea about my case choices i have let me know thanks
