New gaming pc. Need help knowing if parts are compatible with each other
niravkhant
Commendable
Sep 18, 2016
12
I am going to build a gaming pc for the first time so I need help with knowing if all my parts are compatible with each other. I also need to know if I am missing any parts or any good recommendation for changing parts.
CPU
Intel i7 7700k quad core processor
https://in.pcpartpicker.com/product/VKx9TW/intel-core-i7-7700k-42ghz-quad-core-processor-bx80677i77700k
Motherboard
MSI Z270 gaming pro carbon ATX LGA1151
https://in.pcpartpicker.com/product/yY8H99/msi-z270-gaming-pro-carbon-atx-lga1151-motherboard-z270-gaming-pro-carbon
Graphics card
Asus GeForce GTX 1050Ti 4gb strix
https://in.pcpartpicker.com/product/RDQRsY/asus-geforce-gtx-1050-ti-4gb-strix-video-card-strix-gtx1050ti-o4g-gaming
RAM
Corsair vengeance LPX 16gb (1x16gb) DDR 4 2400
https://in.pcpartpicker.com/product/dDTrxr/corsair-vengeance-lpx-16gb-1-x-16gb-ddr4-2400-memory-cmk16gx4m1a2400c14
PSU
Corsair VS 650w ATX Power supply
https://in.pcpartpicker.com/product/FxDwrH/corsair-power-supply-cp9020051ww
SSD
Samsung 850 Evo series 250 GB 2.5" SSD
https://in.pcpartpicker.com/product/3kL7YJ/samsung-internal-hard-drive-mz75e250bam
HDD
Seagate - Barracuda 2TB
https://in.pcpartpicker.com/product/CbL7YJ/seagate-barracuda-2tb-35-7200rpm-internal-hard-drive-st2000dm006
CPU cooler
cooler master hyper 212 LED 66.3 CFM rifle bearing
https://in.pcpartpicker.com/product/YdJkcf/cooler-master-hyper-212-led-663-cfm-rifle-bearing-cpu-cooler-rr-212l-16pr-r1
Case
thermaltake commander G42 ATX mid tower case
https://in.pcpartpicker.com/product/pyw323/thermaltake-case-ca1b500m1wn00
Thanks in advance guys.
niravkhant
Commendable
Sep 18, 2016
12
Thanks. So which is the best option according to you??????
KahouAoki
289
46
Well, it depends. How much are you looking to spend, will you be doing anything else but gaming with this system, do you want to have room for future upgrades?
niravkhant
Commendable
Sep 18, 2016
12
Right now I can spend around 20K (INR). I am going to use this pc mostly for graphic design work and gaming. I can spend in future but it depends but not right now.
KahouAoki
289
46
I would say that the components with the best value are the ones that last the longest. I don't know about pricing in India, but I would seriously look into the AM4 platform. The 7700K is very good now, yes, but you're going to be stuck with just that cpu, since there's no upgrade path.
However, even a simple build will go over your budget.
hang-the-9
Spending too much on the CPU and too little on the power supply and video card. The Corsair VS is the lowest quality power supply from them. You should get the CXM series at least.
Drop the CPU to an i5, get a GTX 1060 6gb video card instead of the i7.
Are you planning on overclocking? You can save more money by getting a cheaper motherboard and a non-K CPU and put that towards a faster video card and better power supply, maybe a better monitor.
niravkhant
Commendable
Sep 18, 2016
12
I want to use same cpu. I can buy CMX series PSU.
So you are saying that instead of GTX 1050Ti 4gb strix 1060 6gb is far better so how about this 2?
https://in.pcpartpicker.com/product/QVWrxr/zotac-geforce-gtx-1060-6gb-amp-edition-video-card-zt-p10600b-10m
https://in.pcpartpicker.com/product/pbL7YJ/evga-geforce-gtx-1060-6gb-gaming-video-card-06g-p4-6161-kr
hang-the-9
Yes a 1060 card is quite a bit better than the 1050 Ti, and will be a better match to the rest of the system. Either of those cards are fine, EVGA is probably the more reliable brand.
Similar threads
