New GPU, having shutdown issues (possible PSU too weak?) Please Help!
Nov 25, 2018
Hi all, i recently upgrade to a RX570 from two Radeon HD 7850 in crossfire. Everything installed fine and powered up however I am having random shutdowns (complete shut down, no BSoD or autorestart) since I switched over. I have been unable to replicate the issue as I can go play a game like GW2 at max without issue for hours then be surfing the web / watching twich and BOOM power down. I believe my issue might be the PSU (currently running 630-Watt) not having enough throughput for my entire build. I did one of those wattage calculators and it recommends a 1200+ watt PSU. If I do need a PSU I would try to buy one under the cybermonday deals and thus the urgency for advice.
My current full system is:
-MB: BIOSTAR TA990FXE AM3+ AMD 990FX +
-CPU: FX-8350 Black Edition Vishera 8-Core 4.0 GHz (4.2 GHz Turbo)
-GPU: MSI Radeon RX 570 DirectX 12 RX 570 ARMOR MK2 8G OC 8GB
-PSU: Rosewill RG630-S12 - Green Series 630-Watt Active PFC Power Supply Unit - Continuous @ 104 Deg. F (40C), 80 PLUS Bronze Certified, Single 12V Rail, Compatible with Core i7, i5
-Ram: G.SKILL Ares Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C10D-16GAB
-SSD: SAMSUNG 850 EVO 2.5" 500GB SATA III
-HD: WD VelociRaptor WD5000HHTZ 500GB
I was thinking of purchasing a 850W PSU however do not know if that will be enough with all that I am running. Any advice would be greatly appreciated!
How OLD is that power supply? I know that 630w platform, and it wasn't all that bad (But it wasn't all that great either) on the Thermaltake Berlin units, but I know it's not nearly as good in the Rosewill models AND that unit has not been sold for MANY years so the chances are VERY good that your unit has seen the end of it's better days.
There are certainly other possibilities, but I would certainly start there with a better unit, and then try to figure things out further after that. Even if that unit is not the main issue, it is certainly AN issue especially considering the probable age of the unit.
The capacity isn't the issue though, it's the fact that it's very unlikely that unit is still capable of supporting the same capacity...
The capacity isn't the issue though, it's the fact that it's very unlikely that unit is still capable of supporting the same capacity it once did, or any capacity under sustained loads.
Any very good 550-750w unit would be plenty for your configuration.
Click the spoiler box for PSU recommendations.
Let's start with the biggest misconception out there, which is that if a unit has high watts it will be ok or is good. No. Just, no.
There are plenty of 750-1000w units out there that I wouldn't trust to power a light bulb and might in fact be more dangerous due to their supposedly high capacity due to poor or non-existent protections inside the unit.
If the platform isn't good to begin with, how many watts or amps it says it can support is irrelevant.
Higher 80plus certification doesn't mean anything, UNLESS it's on an already known to be high quality PSU platform. For example, a Seasonic Prime platinum unit is going to be a better product than a Seasonic Prime Gold unit, because we already know the Prime platform is very good, and platinum efficiency along with it shows there are some improvements internally to account for the higher efficiency.
In a case like that, it might be worth it. It's likely the unit will create less heat, it will probably have better performance in regard to ripple, noise and voltage regulation. It might shave a few pennies, or dollars, off the electric bill over the course of a year.
Other than that, it is not going to perform any better than the same platform with Gold efficiency. On the other hand, just because a unit has Titanium 80plus ratings doesn't mean the unit is any good at all. For example, there are Raidmax units with Titanium efficiency and I wouldn't trust one of those to power a light bulb. There are a lot of units like this out there.
If the platform isn't good to begin with, whether or not it has an 80plus certification or not is irrelevant.
Whatever you do, don't EVER buy a power supply based on whether it has RGB or lighting, or looks like it might be a quality unit. Some of the biggest hunks of junk out there look just as good as a Seasonic Prime Ultra Titanium, but I assure you, they are not. So far as I've seen there are really no excellent units out there that have RGB built in. Maybe one or two models, but rest assured you'll be be paying for the lighting, not for the quality of the power supply.
I don't know what country you reside in, and I know that sometimes it's hard to come by good units in some regions, but when possible, when it comes time to get that PSU, I'd stick to the following if you can.
Seasonic. Just about anything made by Seasonic is good quality for the most part. There are really no bad Seasonic units and only a very few that are even somewhat mediocre. They do make a few less-good quality OEM style units, but mostly those are not going to be units you come across at most vendors, and they are still not bad. Also, the S12II and M12II 520 and 620w units are older, group regulated models. At one time they were among the best units you could buy. Now, they are outdated and not as good as almost any other Seasonic models. They are however still better than a LOT of newer designs by other manufacturers.
The Seasonic 520w and 620w S12II/M12II units CAN be used on newer Intel platforms, if you turn off C6/C7 in the bios, but I'd really recommend a newer platform whenever possible. Prices are usually pretty good on those though, so sometimes it's worth accepting the lack of DC-DC on the internal platform. Higher capacity versions of the High current gamer are not based on that platform, so they are fine. Those being the 750w and higher versions.
Corsair. The CX and CXm units are ok as a budget option, but I do not recommend pairing them with gaming cards. The newer 2017 models of CX and CXm are better than the older ones, but still not what we'd call terrific, so if it specifically says 2017 model, or it has a capacity other than an even 100, like 550w, 650w, 750w, etc., then it's likely at least better than those older ones. Aside from that, any of the TX, RMx, RMi, HX, HXi, AX or AXi units are good. Those are listed from best to worst, with the best being the AX and AXi units.
Antec. The True power classic units are made by Seasonic, and are very good, but are not modular. The High current gamer 520w and 620w, or any other PSU you see on the market that is 520w or 620w, are also made by Seasonic, based on the S12II and M12II platform for modern versions, and are pretty good units but again they are an older platform that is group regulated so if you go with a Haswell or newer Intel configuration you will want to avoid those because they do not support the C6/C7 Intel low power states.
The Antec High current gamer 750w and 850w units are very good and are not the older design, which came in 520w and 620w capacities and were good for back then but again, are an aging Seasonic platform that is not the best choice most of the time these days. Occasionally, these older units MIGHT be the best unit available and you could do worse than one of them, but a newer DC-DC platform is desirable when possible if it doesn't mean sacrificing quality elsewhere in the platform. There are however older and newer HCG models, so exact model number will likely be a factor if choosing one of these however both the older models and the newer models are good.
Antec Edge units are ok too, but reviews indicate that they have noisy fan profiles. I'd only choose this model if it is on sale or the aesthetics match up with your color scheme or design. Still a good power supply but maybe a little aggressive on the fan profile. This may have been cured on newer Edge models so reading professional tear down reviews is still the best idea.
BeQuiet. BeQuiet does have a few decent models, BUT, you must be VERY selective about which of their models you put your trust in. From model to model their are huge differences in both quality and performance, even with the same series. If you cannot find a review for a BeQuiet unit on HardOCP, JonnyGuru or Tom's hardware that SPECIFICALLY says it is a very good unit, and does not have any significant issues in the "cons" category, I would avoid it. In fact, I'd probably avoid it anyhow unless there is a very great sale on one that has good reviews, because their units are generally more expensive than MUCH better units from Antec, Seasonic, EVGA and Corsair.
Super Flower. They are like Seasonic and they make power supplies for a variety of other companies, like EVGA. Super Flower units are usually pretty good. I'd stick to the Leadex, Leadex II and Golden Green models.
EVGA. They have BOTH good and not very good models.
Not very good are the W1, N1, B1, B3, BR (All models except the 650w model) and G1 NEX models.
Good models are the B2, B3 650w, G2, G2L, G3, GQ, P2 and T2 models.
FSP. They used to be very mediocre, and are a PSU manufacturer like Seasonic and Super Flower, although not as well trusted based on historical performance. Currently the FSP Hydro G and Hydro X units are pretty good.
I would avoid Thermaltake and Cooler Master. They do have a few good units, but most of the models they sell are either poor or mediocre, and the ones they have that ARE good are usually way overpriced.
This is just ONE example of why I say that. Very new and modern CM unit. One of the worst scores ever seen on JG for a well known brand name product. Doesn't look to be much better than a Raidmax unit. Sad.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=563
And most of the models I have linked to the reviews of at the following link are at least good, with most of them being fantastic.
Certainly there ARE some good units out there that you won't see above among those I've listed, but they are few and far between, much as a hidden nugget of gold you find in a crevice among otherwise ordinary rocks and don't EVER assume a unit is good just because of the brand.
If you cannot find an IN DEPTH, REPUTABLE review on Tom's hardware, JonnyGuru, HardOCP, Hardware secrets (Old reviews by Gabe Torres), Kitguru (Only Aris reviews), TechPowerUP, SilentPC crew or a similar site that does much more than simply a review of the unboxing and basic tests that don't include reliable results for ripple, noise, voltage regulation and a complete teardown of the unit including identification of the internal platform, then the unit is a big fat question mark.
I recommend not trusting such units as companies generally always send out review samples of any unit they feel is going to get a good review, and don't send them out if they know they are going to get hammered by the reviewer. No review usually equals poor quality. Usually.
Other models that should never be trusted OR USED AT ALL, under any circumstances, include A-Top, Apevia, Apex (Supercase/Allied), Artic, Ace, Aerocool (There might be one model worth using, but I'd still avoid them.), Aspire (Turbocase), Atadc, Atrix, Broadway com corp, CIT, Coolmax, Deer, Diablotek, Dynapower, Dynex, Eagletech, Enlight, Evo labs, EZ cool, Foxconn, G7, HEC/Compucase Orion, HEDY, iBall, iStar computer co., Jeantec, JPac, Just PC, Linkworld electronics, Logisys, Macron, MSI, NmediaPC, Norwood Micro (CompUSA), Okia, Powercool, Powmax, Pulsepower, Q-tec, Raidmax, RaveRocketfish, SFC, Sharkoon, Shuttle, Skyhawk, Startech, Storm, Sumvision, Tesla, Trust, Ultra, Wintech, Winpower, Xilence (Until I see a reputable review of a model showing different), xTreme (Cyberpower), Youngbear and Zebronics.
Hi Darkbreeze, thank you for your response and the recommendations on different PSU. Yes the unit is pretty old, bought in 2012 and has seen heavy use over the years. I think I will follow your advice and upgrade the PSU. The G2 was on your approved list is currently on a great sale on one of the popular sites and I think I will give that a try.
