A few weeks ago I ordered a new Radeon XFX 7850 1GB Core Edition card. When it arrived I found that I needed an adapter to use it with my monitor. So I ordered one but in the mean time i wanted to test the card out and see if it worked. I used a friends monitor and it worked great no problems. I installed my old Radeon 6670 and waited for the adapter to arrive.
I got the adapter in the mail, hooked everything up and when I turned on my PC I got the "disk read error. Press ctrl+alt+delete to restart" message. I restarted several times and the same thing kept happening. I thought maybe a cable came loose. So I opened my PC up and unplugged the drive cables on both ends for the Hard drive and plugged them back in making sure they were secure. Booted it up and got the same message. After restarting a few more times I got a windows screen that displayed some errors. There were two, one pertaining to a kernel and the other to a bootloader. I rebooted one more time and windows started up but it was really slow. I got to my desktop and everything was also really slow at loading and would lock up every couple of seconds.
I figured maybe some Windows files got corrupt or something during the installation of my new card. So I used my backup disk to "Refresh Windows". It deleted all my apps and programs and replaced the old windows files with the backup ones. The "disk read error" and the other error messages stopped showing up and my computer boots up now.
The thing is it boots up way slower than it used to. I'd say it averaged about 5 to 10 seconds at the most before I put the new card in. Now it takes about 20 to 30 seconds. Also, it boots up twice every time I turn it on. I'll see the MOBO logo and hear the beep, then windows logo will appear for a split second then it will boot up again and show the MOBO logo once more and beep again as well and then it finally loads up. Sometimes when I turn it on it will beep and after the MOBO logo appears I get a "no signal" message on my monitor and it shuts off and I have to reset it to get it to boot up. I noticed after it reboots the second time when it's loading my login screen all I see is a black screen and my hard drive light on my tower lights up and stays solid as if its really struggling to load it.
I've done every possible test and scan on the hard drive and every single one of them said the hard drive was ok. I checked my RAM and that is ok too. No scans showed any errors. I defragged the hard drive, did registry scans, driver scans....everything. I have no idea what could be wrong. Another thing I noticed was "Service Host: Local System" is now constantly using 80 - 100% of my CPU unless I go into it and stop the "SuperFetch" process. Not sure if that has anything to do with it or not.
I'll post my PC specs below. Any help at all would be greatly appreciated.
