New graphics card no display help
Augustaronio
7
Just got a new Asus radeon 7770 graphics card when I plug it in the cards light is green and the fans on my computer and can spin but the power buttons isn't lit up but it's still use able an d there's no display on my screen please help
Power buttons don't lit up??? Check the 6-pin connectors, people sometimes do forget to plug in 6-pin hence power lights on the card dont come on...
Since I solved many people with typical problems like yours, just switch back into on-board graphics and go into your bios. Check to see an option called "PCI-e adapter" and see what your motherboard switched to. Sometimes removing hardware, your bios will reset the settings, and just change it back to PCI. If that doesn't work, check windows...
Since I solved many people with typical problems like yours, just switch back into on-board graphics and go into your bios. Check to see an option called "PCI-e adapter" and see what your motherboard switched to. Sometimes removing hardware, your bios will reset the settings, and just change it back to PCI. If that doesn't work, check windows. Often enough windows sometimes will not recognize the new hardware, just go to Device Manager and under display adapters, click on it and see what it says. If its not detected it will have "unknown device" and just browse around the tabs to find hardware detection. Click it and it will refresh and hopefully windows will recognize the hardware.
Post your computer specs, since I don't know, it wont help. Especially if you are using a pre-built / bought computer like HP, they can limit the bios to not have new hardware installed.
same person different account uhm its a hp pavillion p6240f and i have a antec 450w strictly power psu with the 2gb asus radeon 7770 need help as to why no display using hdmi and tried vga to dvi adapter also
That 450w psu should be more than enough for this card, even though 500w is usually the recommended. Have you checked your bios??
ive slelected pcie x16 as the defualt i feel like theres something interupting the connection or shorting it idk just need help when i hook up the pcie 6 pin too the card and turn on the pc the power button on my case doesnt light up but the button still works idk pls help
When you plug in 6-pin into the graphics card the computer won't turn on...that is a case where your power supply doesn't supply enough power to run everything. Hence the reason when you try to start it, no lights come on.
Then when you installed your graphics card into your computer, you might have ESD discharge that damaged something in your computer hence why part of it works and part of it doesnt. I suggest trying your graphics card on another computer and see in their rig if it boots up. If it does then it means you did something very wrong when you installed it in your computer.
but if i boot with onboard everything works so either its a power thing or idk the rigs fine woth on board but i feel my psu might just be a little less than what i need im gunna try a 600 watt in it and see if it boots thanks for the help
