New Hard Drive Strange Problems
ThreeChainz
I just installed a new hard drive today straight out of the box. I want to take ownership of it so i can use it, so i go into the properties, advanced, blah blah, and then i get to the part where i have selected the right user, check the box that allows the transfer of ownership, and it always says denied, no matter what i do
Hey there, ThreeChainz.
What OS are you using? Try the drive with a different SATA port and different cables as well, to see if the same thing happens. You could also check out this thread here: http://answers.microsoft.com/en-us/windows/forum/windows_7-performance/access-denied-when-trying-to-take-ownership-of-an/0778dc1c-417d-4536-aa07-2f4bef614914?auth=1. It has some tips and guides on what might work in a situation like yours.
Note that it should be initialized, partitioned and formatted via Disk Management before you start doing anything else with it.
Hope that helps.
Boogieman_WD
Ok how can i format the new hard drive? i have never worked with storage devices before
