New i7-7700 short temp spikes and a very loud cooler problem
ombh420
i7-7700(non k) gigabyte
h110m-a
windows 8.1 pro
HWMonitor to watch temps
If you do a search for i7-7700 temp spikes/surges you will see a great number of people complaining about the chip having very short 40 degree temperature spikes when opening a web browser or something from idle. I was able to solve this by switching from performance to balanced power mode in windows power settings. I was just wondering if there is any new information that anyone knows? While there is alot of complaints there are not alot of solutions that dont have to do with changing settings on a z serious motherboard that I cant do. is this just a bad luck in the silicon lottery?
My other worry is that while under load this stock cooler is very loud. I just switched from a i3-6100 and had a i5-4460k before that. Each of the coolers were extremely quiet compared to this. Is this normal for the 7th gen chips? Did intel just clock them super high or something?
I should say under load the chip never really goes about 74 degrees Celsius and I have never seen it get beyond 80c.
Are either of these issues worth sending the chip back? Or should I just get another cooler that it quieter? The only cooler I have lying around is one from a dell xps 630i that went on a q6600. Is that worth using if it fits?
Thanks for any help.
What cooler are you using as of this moment?? I know the 7gen didn't come with coolers; maybe you want to big up like a Hyper 212 evo. Also did you make sure to apply fresh thermal paste and correctly apply it? Check the cpu temp spikes, if one like one or two of the cores are getting hot and the rest are staying cool at ideal maybe you didn't apply the thermal paste correctly and is cooling unevenly. The i7-7700 is still a very strong cpu so 40C under a little stress is honestly not that big of a deal. If it was like 60c while opening notepad then there is a problem haha, most cpus ideal at about 35C anyway.
K Versions do not come with stock coolers for (intel i3-7350K, Intel i5 7600K, Intel i5 7640K, Intel i7 7700K and Intel i7 7740K
74C during a full load is not even really that high. Its a 8 threaded cpu at 4.2ghz stock and he is cooling with Air. That temp is totally fine for that.
Sorry, I should of been clearer. Yes im using the stock cooler that came with the 7700. I guess I can get some new thermal paste and try the the cooler I have for the i3-6100 and see if thats any better. While gaming what should the 7700 temp be?
No i think your CPU is fine on a 65 Watts TDP CPU.
Well here is what the temps looked liked after swapping around stock coolers. This is after a couple of hours of gaming.
http://i.imgur.com/raeod8D.jpg
Judging by all the threads I link kaby lake i7s just run hotter than previous gens. Please let me know if anything from that picture seems off though. Thanks for all the help.
Kaby Does run hotter that's a known fact...You are correct.
So it was probably something improperly placed.
I think your Temp are fine as people said.
