Here's a quick link to a clip from my stream you can hear what I am having trouble with.
https://clips.twitch.tv/ExquisiteTawdryEggnogSeemsGood
I'm not sure what I'm doing wrong? My google searches have come up with similar but not the same problem. Any advice is greatly appreciated and I apologize for my noobness, I am new here and to streaming.
Before this I used a razor headset with no problems. The only thing I can think of is the new cam I have bought logitech c920 is also using its mic even though I have disabled its output in slobs (stream labs obs).
Perhaps the mic is too close or too far? I should also mention I have a fan blowing on my and you can hear it faintly in the clip but I am not worried about this.
I just want a the mic to sound as normal as possible, I know I can tweak all further settings with 3rd party freeware.
tldr: My mic sounds weird, like an echo.... snowball blue / webcam logitech c920 / windows 10 / 16 gigs ram / msi geforce 1060 6gigs vram / i5 4460 cpu @ 3.20ghz / the cam and mic are both plugged in usb 3 / my head set is plugged in usb 1 / webcam and headset both have mic input disabled in OBS.
link to clip again https://clips.twitch.tv/ExquisiteTawdryEggnogSeemsGood
cheers
Blackout
cheers
Blackout
