I upgraded my motherboard, cpu and cooler and it seemed like everything was OK but after a few days of usage I have a very annoying problem where the VGA led light on the mobo turns on and the system doesn't boot at times. After I remove the GPU and insert it again, sometimes it starts working.
The weird part is that if the system boots then it's pretty stable. I can stress test, run game benchmarks and nothing crashes. The problem is that if I leave it alone and come back the next day it won't boot at first.
System is:
Any ideas what could be causing the issue? The GPU is heavy and long, is it just not connecting properly to the mobo? It worked for years fine in a MSI B450M Pro-VDH I had before. Also don't thing the GPU is broken as when it boots, it works.
Could it be the PSU not having enough power for all the components? Previously I had a 2400G that is lower TDP.
Already tried removing everything from the case and tried to boot it that way but it seems it's even worse.
System is:
- Mobo: Asus TUF GAMING B550M-PLUS
- CPU 5800x
- cooler: thermaltake peerless assassin 120
- GPU: RX 5700x
- PSU: Bitfenix Formula Gold 450W
- 4 sticks of Gskill 3600Mhz DDR4
