New Monitor - Need Help
G
Guest
Guest
Hi,
I am looking to buy a new monitor which I can hook my PS3 (using component cause of happauge), DVI for the PC and an HDMI as well. So far I have only found the Samsung SyncMaster T24A550, but it doesn't have a DVI. So I was wondering if anyone knows a good monitor around 200 euro.. +/- 20euro that could give me all these inputs.
The least expensive monitor I know of that has DVI, HDMI, and component inputs is the Samsung P2770HD, but I think it might be a little expensive for you. If you're willing to connect the PC via HDMI instead (possibly with the use of a DVI to HDMI adapter), there are some small HDTVs with 2 HDMI ports that are probably within your budget, such as the Samsung UN22D5003.
Thanks MauveCloud. I think I will just connect my PC with an HDMI cable. Apparently its just as good as a DVI.
