New motherboard, nothing gets power besides CPU fan and PSU led's and fan.
Namingishard
Motherboard - Asus p5lp le
CPU - Duo core E5200
GPU - Eadeon 4670
Power Supply - Rosewill RD500-2DB 500w
So awhile back i spilled something on my motherboard and it fried. I finally got a new motherboard but after i put it in and hooked everything up I get no power to anything besides the CPU fan. None of the other fans plugged in work, it doesn't boot and i don't get a signal to the monitor.
Are my parts not compatible? I did as much research as i could and it seemed like everything should work with it.
Also, i don't know if this means anything but now my computer starts as soon i flip the switch on the power supply and not when i hit the power button.
"my computer starts as soon i flip the switch on the power supply"
Check that you've wired up the power button correctly and that it's physically operating properly as it may be jammed in the "on" position.
