New nzxt phantom fan led
andrewtkd123
8
Hello, i finished building my black nzxt phantom, and i was wondering does the top 200mm or any of the white fans have a blue led around anything? I saw on the website the top one is supposed to have blue lights, idk if its me. I can buy blue led fans whenever but is this case supposed to come with some sort of led fans or anything already equipped?
Yeah, it's meant to come with the 200mm blue led fan on the top - there is a switch on the back, a small black one to turn it on, so you should try that. If that doesn't work then you will have to go and buy one, if you really wanted one :)
