New Parts BSOD
Kamil Cziba
29
Hi,
I've recently change some parts of my PC:
Asrock Z77 Extreme4
i5 3570K
2x4GB Adata 1600 MHz cl9
My gpu is MSI GTX 660, PSU is BeQuiet 450W
Since then i'm having bsod's.
I've checked with 3 different version sets of drivers,
checked my memory with memtest - 8 passes no erros,
switched slots of my ddr3 and gpu
ran driver verifier - showed blue screen with my mouse drivers - I removed it but still didn't help.
What could be the reason ? I'm helpless.
Here is zip with all the minidumps sicne last windows reinstall:
https://docs.google.com/file/d/0BzZzjdmJquKYSmJ1NnIzdnd0Slk/edit?usp=sharing
I placed this on another post. Thought it might help. I chased Direct X and software problems for 2 months. Today I found the issue. Considering you moved stuff around I think you had the same problem as me. Hope the following helps:
The very same problem has plagued me since March 29th and it has been driving me nuts. I have gone through a TON of troubleshooting too and had replaced a hard drive and a sound card. At times I even felt it was fixed then sadly found out an hour later that it was not. My PC is only 3 years old and I felt it was not old enough to be experiencing problems.
Well today I am confident I found the solution.
Below was the exact error I was receiving...
So i did all that. I was running verifier for few hours with runing game watchign stream and some other program in background. Nothing happened. So i turned it off, and when i was playing game next day - bsod.
Here are some more dumps:
https://docs.google.com/file/d/0BzZzjdmJquKYWnZLRDRjREtPNmc/edit?usp=sharing
Could it be PSU ? Or ddr anyway although it went through 8 passes ? Should I run it again ?
Edit:
I also noticed that when i play game they crash a lot, and when they crash theres usually some corrupted file so they require reinstall or using some repair tool. Sometimes they freeze for split second like about to crash or bsod.
Driver Verifier really needs to be run for 24-48 hours, or at least across several session - but - we may have the culprit.
There was 1x Driver Verified crash, it pointed to the Lachesis.sys driver:
Fri Oct 16 14:09:12 2009 (4AD87078)
Razer Lachesis Mouse driver
http://www.carrona.org/drivers/driver.php?id=Lachesis.sys
Update the Razer drivers if you can (they don't update very often), if there's no update, uninstall it from Device Manager, when it asks about deleting the drivers, select to delete them. Disconnect the mouse and reconnect it, this time, only install it as a standard mouse.
Then turn DV back on and test again.
Yes, it does look like the crash was blamed on the nVidia drivers, however, the Lachesis.sys driver could well be the trigger (mouse drivers are tied into the graphics or there'd be no cursor onscreen interaction); also the DaemonTools drivers are still there, they can cause very strange effects.
Turn off Driver Verifier, uninstall the Lachesis (test with a standard mouse for a few days), uninstall DaemonTools completely, reinstall (or install a different version of) the nVidia drivers. Then turn DV back on, test for 1-2 days; try to collect 3x DV verified dumps.
intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
Intel Processor driver
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
MBfilt64.sys Fri Jul 31 04:40:32 2009 (4A7267B0)
Realtek HiDefinition Audio driver (file labelled as Creative Audio Driver)
http://www.carrona.org/drivers/driver.php?id=MBfilt64.sys
Lachesis.sys Fri Oct 16 14:09:12 2009 (4AD87078)
amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
AMD storage controller driver - usually from the Windows 7 DVD
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
asmtxhci.sys Fri Mar 4 07:54:59 2011 (4D709AD3)
Asmedia USB 3.0 driver
http://www.carrona.org/drivers/driver.php?id=asmtxhci.sys
asmthub3.sys Fri Mar 4 07:55:10 2011 (4D709ADE)
ASMedia USB 3.0 Hub driver
http://www.carrona.org/drivers/driver.php?id=asmthub3.sys
k57nd60a.sys Tue May 10 05:42:30 2011 (4DC8C236)
Broadcom NetLink Gigabit Ethernet NDIS6.x Unified Driver
http://www.carrona.org/drivers/driver.php?id=k57nd60a.sys
asahci64.sys Wed Sep 21 10:42:57 2011 (4E79B1A1)
Asmedia 106x SATA Host Controller Driver
http://www.carrona.org/drivers/driver.php?id=asahci64.sys
RTKVHD64.sys Tue Jan 31 10:55:06 2012 (4F27C88A)
Realtek High Definition Audio Function Driver
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
iusb3hub.sys Mon Feb 27 10:56:50 2012 (4F4B6172)
Intel(R) USB 3.0 Hub Driver
http://www.carrona.org/drivers/driver.php?id=iusb3hub.sys
iusb3xhc.sys Mon Feb 27 10:56:53 2012 (4F4B6175)
Intel(R) USB 3.0 eXtensible Host Controller Driver
http://www.carrona.org/drivers/driver.php?id=iusb3xhc.sys
iusb3hcs.sys Mon Feb 27 10:58:49 2012 (4F4B61E9)
Intel(R) USB 3.0 Host Controller Switch Driver
http://www.carrona.org/drivers/driver.php?id=iusb3hcs.sys
IntcDAud.sys Tue Jun 19 15:40:51 2012 (4FE08F73)
Intel Graphics Media Accelerator HD Driver
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
HECIx64.sys Mon Jul 2 23:14:58 2012 (4FF21D62)
Intel Management Engine Interface
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
sptd.sys Sat Aug 18 22:05:38 2012 (503003A2)
SCSI Pass Through Direct Host - Daemon Tools (known BSOD issues with Win7)
http://www.carrona.org/drivers/driver.php?id=sptd.sys
MpFilter.sys Wed Oct 31 22:43:06 2012 (5091A97A)
Microsoft Windows AntiMalware protection system
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
igdkmd64.sys Thu Dec 13 00:42:26 2012 (50C92472)
Intel Graphics driver
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
nvhda64v.sys Wed Dec 19 05:41:41 2012 (50D15395)
nVidia HDMI Audio Device (nForce chipset driver)
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
HWiNFO64A.SYS Sat Jan 26 12:28:11 2013 (5103CBDB)
HWiNFO32 Kernel Driver
http://www.carrona.org/drivers/driver.php?id=HWiNFO64A.SYS
nvlddmkm.sys Fri Mar 15 01:37:00 2013 (51427B3C)
nVidia Video drivers
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
RzFilter.sys Wed May 1 01:47:49 2013 (51806635)
RzFilter.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
RzDxgk.sys Wed May 1 01:47:51 2013 (51806637)
RzDxgk.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
BSOD BUGCHECK SUMMARY
Code:
System Uptime: 0 days 1:11:10.059
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+19c62d )
BugCheck D6, {fffff980546b7ba8, 1, fffff88004bcb62d, 0}
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000D6]DRIVER_PAGE_FAULT_BEYOND_END_OF_ALLOCATION (d6)[/url]
Bugcheck code 000000d6
Arguments:
Arg1: fffff980546b7ba8, memory referenced
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation
Arg3: fffff88004bcb62d, if non-zero, the address which referenced memory.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR:  0xD6
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
PROCESS_NAME:  dota.exe
FAILURE_BUCKET_ID:  X64_0xD6_VRF_nvlddmkm+19c62d
MaxSpeed:     3400
CurrentSpeed: 3400
BiosVersion = P2.80
BiosReleaseDate = 01/17/2013[/font]
Ok, I uninstalled sptd, but when I uninstall Lachesis the Lachesis.sys is still there. When i remove it manually then my mouse doesnt work, even if I unplug and plug in again. So no idea how to remove it.
First get hold of a standard mouse for testing with then connect it, remove the Lachesis and uninstall it. Go to Device Manager > View > Show hidden devices and look for it in the Non-Plug and Play section and uninstall it from there, you should get a pop up asking if you also want to remove the drivers for it, choose yes/ok to that.
Have you updated/switched graphics drivers yet, just in case they were buggy?
This dump was a 0x1A Memory Management, that's usually caused by a driver, bad memory/slot or, very rarely, kernel. I don't see any further clues; can you carefully read and follow the Sticky here please:http://www.sysnative.com/forums/bsod-crashes-kernel-debugging/68-blue-screen-death-bsod-posting-instructions-windows-8-7-vista.html and upload the required zipped folder?
With some extra details, it should be easier to get an overview of what's happening.
I can see nothing conclusive; there's 1 unknown device in Device Manager, that looks like Intel Smart Connect, you could install that for completeness.
Windows Error Reporting does flag application crashes from Razercore.exe in the moments before some of the BSODs, I would remove both the remaining Razer software then continue testing with Driver Verifier.
The latest crash was a 0x1A, frequently caused by a device driver or memory. The drivers look recent with no known 'bad' ones but there's a question mark hanging over the most recent ones - from Razer, by the look of the file names. Uninstall the software that relates to these drivers.
The next stage would be to rule out bad memory/slots, MemTest86+ for at least 7+ runs on each individual stick is best. Do this overnight or while you are away at work or sleeping is best, it takes a long time. Details here: http://www.carrona.org/memdiag.html sections #2 and 7-10.
Code:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18044.amd64fre.win7sp1_gdr.130104-1431
Machine Name:
Kernel base = 0xfffff800`0300c000 PsLoadedModuleList = 0xfffff800`03250670
Debug session time: Fri May 17 08:53:24.729 2013 (GMT+1)
System Uptime: 0 days 0:42:29.572
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 1A, {41790, fffffa8000cd8f60, ffff, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35084 )
Followup: MachineOwner
1: kd> !analyze -v; !sysinfo cpuspeed; !sysinfo SMBIOS; lmtsmn; q
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041790, The subtype of the bugcheck.
Arg2: fffffa8000cd8f60
Arg3: 000000000000ffff
Debugging Details:
BUGCHECK_STR:  0x1a_41790
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  opera.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff800030f2e10 to fffff80003081c40
STACK_TEXT:
fffff880`0a5594b8 fffff800`030f2e10 : 00000000`0000001a 00000000`00041790 fffffa80`00cd8f60 00000000`0000ffff : nt!KeBugCheckEx
fffff880`0a5594c0 fffff800`0306e42f : fffffa80`00000000 00000000`3c79ffff 00000000`00000000 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x35084
fffff880`0a559680 fffff800`03080ed3 : ffffffff`ffffffff fffff880`0a559950 fffff880`0a559958 00000000`00008000 : nt!NtFreeVirtualMemory+0x61f
fffff880`0a559780 fffff800`0307d490 : fffff800`03303fdb 00000000`00000010 00000000`00000082 fffff880`0a559948 : nt!KiSystemServiceCopyEnd+0x13
fffff880`0a559918 fffff800`03303fdb : 00000000`00000010 00000000`00000082 fffff880`0a559948 00000000`00000000 : nt!KiServiceLinkage
fffff880`0a559920 fffff800`0335a0cd : 00000000`3c6a0000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!RtlFreeUserStack+0x27
fffff880`0a559950 fffff800`0335a42d : fffff880`00000000 00000000`2fdae100 00000000`fff1a000 00000000`00000000 : nt!PspExitThread+0x5dd
fffff880`0a559a50 fffff800`0335a535 : fffffa80`0b144060 00000000`00000000 fffffa80`0b144060 00000000`fff1a000 : nt!PspTerminateThreadByPointer+0x4d
fffff880`0a559aa0 fffff800`03080ed3 : 00000000`00000008 fffff880`0a559b60 00000000`fff1a000 00000000`0be9faf0 : nt!NtTerminateThread+0x45
fffff880`0a559ae0 00000000`76d8184a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`2fdae1f8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x76d8184a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`030f2e10 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+35084
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  50e79935
FAILURE_BUCKET_ID:  X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+35084
3rd party driver list:
Code:
The latest dump was a 0xBE, usually drivers or memory.
Your drivers are now looking pretty good but there could be updates available for your hardware drivers, also there are many more recent versions of HWInfo.
You could turn on Driver Verifier on 3rd party drivers to try to flush out any bad driver, info here: http://www.sysnative.com/forums/showthread.php/29-Driver-Verifier-BSOD-related
Debug session time: Sat May 18 10:59:01.089 2013 (GMT+1)
System Uptime: 0 days 2:53:18.323
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+44cde )
BugCheck BE, {fffff8a003fa8767, 80000001951e3121, fffff88009d221f0, b}
BugCheck Info: ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
Bugcheck code 000000bE
Arguments:
Arg1: fffff8a003fa8767, Virtual address for the attempted write.
Arg2: 80000001951e3121, PTE contents.
Arg3: fffff88009d221f0, (reserved)
Arg4: 000000000000000b, (reserved)
BUGCHECK_STR: 0xBE
PROCESS_NAME: GameOverlayUI.
FAILURE_BUCKET_ID: X64_0xBE_nt!_??_::FNODOBFM::_string_+44cde
MaxSpeed: 3400
CurrentSpeed: 3400
BiosVersion = P2.80
3rd party drivers loaded:
this is what i got from 'verifier /query':
Microsoft Windows [Wersja 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Wszelkie prawa zastrzeżone.
C:\Users\qalix>verifier /query
2013-05-19, 11:58:11
Poziom: 0000092B
RaiseIrqls: 0
AcquireSpinLocks: 112476
SynchronizeExecutions: 69
AllocationsAttempted: 58686
AllocationsSucceeded: 58686
AllocationsSucceededSpecialPool: 58686
AllocationsWithNoTag: 37
AllocationsFailed: 0
AllocationsFailedDeliberately: 0
Trims: 75024
UnTrackedPool: 1
Zweryfikowane sterowniki:
Nazwa: iusb3hcs.sys ładowania: 1, usunięcia: 0.
CurrentPagedPoolAllocations: 0
CurrentNonPagedPoolAllocations: 0
PeakPagedPoolAllocations: 0
PeakNonPagedPoolAllocations: 0
PagedPoolUsageInBytes: 0
NonPagedPoolUsageInBytes: 0
PeakPagedPoolUsageInBytes: 0
PeakNonPagedPoolUsageInBytes: 0
Nazwa: asahci64.sys ładowania: 1, usunięcia: 0.
Nazwa: amdxata.sys ładowania: 1, usunięcia: 0.
Nazwa: serial.sys ładowania: 1, usunięcia: 0.
CurrentPagedPoolAllocations: 5
CurrentNonPagedPoolAllocations: 1
PeakPagedPoolAllocations: 7
PeakNonPagedPoolAllocations: 2
PagedPoolUsageInBytes: 256
NonPagedPoolUsageInBytes: 32
PeakPagedPoolUsageInBytes: 1088
PeakNonPagedPoolUsageInBytes: 4144
Nazwa: hwinfo64a.sys ładowania: 1, usunięcia: 0.
Nazwa: nvlddmkm.sys ładowania: 1, usunięcia: 0.
CurrentPagedPoolAllocations: 122
CurrentNonPagedPoolAllocations: 5847
PeakPagedPoolAllocations: 140
PeakNonPagedPoolAllocations: 5864
PagedPoolUsageInBytes: 804844
NonPagedPoolUsageInBytes: 7200548
PeakPagedPoolUsageInBytes: 1915036
PeakNonPagedPoolUsageInBytes: 7203036
Nazwa: igdkmd64.sys ładowania: 1, usunięcia: 0.
CurrentPagedPoolAllocations: 11
CurrentNonPagedPoolAllocations: 1097
PeakPagedPoolAllocations: 13
PeakNonPagedPoolAllocations: 1104
PagedPoolUsageInBytes: 2376328
NonPagedPoolUsageInBytes: 4730912
PeakPagedPoolUsageInBytes: 2380440
PeakNonPagedPoolUsageInBytes: 4732924
Nazwa: iusb3xhc.sys ładowania: 1, usunięcia: 0.
CurrentPagedPoolAllocations: 4
CurrentNonPagedPoolAllocations: 262
PeakPagedPoolAllocations: 5
PeakNonPagedPoolAllocations: 265
PagedPoolUsageInBytes: 484
NonPagedPoolUsageInBytes: 620876
PeakPagedPoolUsageInBytes: 528
PeakNonPagedPoolUsageInBytes: 690444
Nazwa: hecix64.sys ładowania: 1, usunięcia: 0.
PeakNonPagedPoolAllocations: 4
PagedPoolUsageInBytes: 112
NonPagedPoolUsageInBytes: 240
PeakPagedPoolUsageInBytes: 112
PeakNonPagedPoolUsageInBytes: 852
Nazwa: k57nd60a.sys ładowania: 1, usunięcia: 0.
CurrentNonPagedPoolAllocations: 3
PeakNonPagedPoolAllocations: 3
NonPagedPoolUsageInBytes: 516240
PeakNonPagedPoolUsageInBytes: 516240
Nazwa: ndis.sys ładowania: 1, usunięcia: 0.
CurrentPagedPoolAllocations: 6
CurrentNonPagedPoolAllocations: 954
PeakPagedPoolAllocations: 8
PeakNonPagedPoolAllocations: 982
PagedPoolUsageInBytes: 984
NonPagedPoolUsageInBytes: 731048
PeakPagedPoolUsageInBytes: 1296
PeakNonPagedPoolUsageInBytes: 756368
Nazwa: asmtxhci.sys ładowania: 1, usunięcia: 0.
CurrentNonPagedPoolAllocations: 178
PeakPagedPoolAllocations: 2
PeakNonPagedPoolAllocations: 185
NonPagedPoolUsageInBytes: 455684
PeakPagedPoolUsageInBytes: 288
PeakNonPagedPoolUsageInBytes: 456796
Nazwa: nvhda64v.sys ładowania: 1, usunięcia: 0.
CurrentPagedPoolAllocations: 16
CurrentNonPagedPoolAllocations: 42
PeakPagedPoolAllocations: 17
PeakNonPagedPoolAllocations: 42
PagedPoolUsageInBytes: 10048
NonPagedPoolUsageInBytes: 26616
PeakPagedPoolUsageInBytes: 10068
PeakNonPagedPoolUsageInBytes: 26616
Nazwa: iusb3hub.sys ładowania: 1, usunięcia: 0.
CurrentPagedPoolAllocations: 3
CurrentNonPagedPoolAllocations: 13
PeakNonPagedPoolAllocations: 14
PagedPoolUsageInBytes: 8340
NonPagedPoolUsageInBytes: 2056
PeakPagedPoolUsageInBytes: 9956
PeakNonPagedPoolUsageInBytes: 2220
Nazwa: rtkvhd64.sys ładowania: 1, usunięcia: 0.
CurrentNonPagedPoolAllocations: 1190
PeakNonPagedPoolAllocations: 1191
NonPagedPoolUsageInBytes: 1394316
PeakPagedPoolUsageInBytes: 233056
PeakNonPagedPoolUsageInBytes: 1394332
Nazwa: mbfilt64.sys ładowania: 1, usunięcia: 0.
NonPagedPoolUsageInBytes: 144
PeakNonPagedPoolUsageInBytes: 144
Nazwa: intcdaud.sys ładowania: 1, usunięcia: 0.
CurrentNonPagedPoolAllocations: 35
PeakNonPagedPoolAllocations: 37
NonPagedPoolUsageInBytes: 17000
PeakNonPagedPoolUsageInBytes: 22128
Nazwa: asmthub3.sys ładowania: 1, usunięcia: 0.
CurrentNonPagedPoolAllocations: 70
PeakNonPagedPoolAllocations: 73
NonPagedPoolUsageInBytes: 62996
PeakPagedPoolUsageInBytes: 128
PeakNonPagedPoolUsageInBytes: 63324
Nazwa: dump_dumpata.sys ładowania: 0, usunięcia: 0.
Nazwa: dump_msahci.sys ładowania: 2, usunięcia: 1.
Nazwa: dump_dumpfve.sys ładowania: 2, usunięcia: 1.
NonPagedPoolUsageInBytes: 16400
PeakNonPagedPoolUsageInBytes: 16400
Nazwa: atmfd.dll ładowania: 1, usunięcia: 0.
Nazwa: secdrv.sys ładowania: 1, usunięcia: 0.
PeakPagedPoolAllocations: 3
PeakPagedPoolUsageInBytes: 316
Study the page again:
DRIVER VERIFIER
Windows 8, Windows 7, Vista
If your BSODs are software related, Driver Verifier can help by subjecting 3rd party drivers to a variety of stresses and tests to find improper behavior. Driver Verifier monitors kernel-mode drivers and graphics drivers to detect illegal function calls or actions that might corrupt the system.
If Driver Verifier detects a violation, it will flag (disable) the offending driver and force a BSOD. The additional info added to the memory dump file will hopefully yield clues.
1. Create a Windows System Restore Point -
Vista - START | type rstrui - create a restore point
Windows 7 - START | type create | select "Create a Restore Point"
2. Run Driver Verifier -
START | type verifier | make these selections -
1. Select 2nd option - Create custom settings (for code developers)
2. Select 2nd option - Select individual settings from a full list
3. Check these boxes -
▪ Special Pool
▪ Pool Tracking
▪ Force IRQL checking
▪ Deadlock Detection
▪ Security Checks (new as of Windows 7)
▪ Concurrency Stress Test (new as of Windows 8)
▪ DDI compliance checking (new as of Windows 8)
▪ Miscellaneous Checks
4. Select last option - Select driver names from a list
5. Click on the Provider heading - sorts list by Provider
6. Check ALL boxes where "Microsoft" IS NOT the Provider
7. Click on Finish
8. Re-boot
If you are unable to boot into normal Windows after VERIFIER_ENABLED BSOD -
... • Boot into SAFEMODE - tap the F8 key repeatedly during boot-up
... • Select "System Restore"
... • Choose the restore point that you created in step #1
To check Driver Verifier status -
--- select last option, 1st screen -or-
--- type verifier /query (in a cmd/DOS screen)
- To turn Driver Verifier off - verifier /reset then re-boot
- Driver Verifier needs to run for 24 hours minimum - even if the status screen appears clear.
If a VERIFIER_ENABLED BSOD occurs, please get the dump file from c:\windows\minidump, zip it up & attach to your next post.
