Hi guys, this is my first time posting on this website, and I'm in desperate need of your help.
So I finally got together all of the parts I wanted for my computer upgrade, and now I'm faced with a couple of problems. As a little backstory, I got the power supply yesterday, opened up all the new parts and started putting them in my case. I doubt I did any physical damage to my components, but it did take a few hours of connecting and disconnecting various parts. The RAM at first came up as incompatible, but that was only because I hadn't properly installed it. I used the RAM from my old build(seeing as it was on the QVL list) but also did not properly install it. After biting the bullet and watching a how-to video on RAM installation to make sure I was doing it correctly(I wasn't applying enough force and the sticks weren't sitting in the slots fully) I was able to install the original new RAM I purchased and everything went fine.
I accidentally set the boot priority to the HDD from the previous build, and it started up perfectly fine, with the exception of a few drivers not being installed. I did not want to do this seeing as I read there would be issues with previous drivers for the old rig being on the new rig and not working, so I restarted the computer and went back into BIOS to boot from the windows 7 disk I had handy(from a laptop at least 2 years ago, however, the disk still works.) This is where I encountered my second problem: I originally planned on backing up my files onto a my passport ultra, and wiping the HDD clean of the files and drivers of the old rig, then restoring the backup once I had a fresh start on windows. There was no new partition, now way of making a new partition, and no way to repair or upgrade windows. I'm not exactly sure how, but after a few tries I managed to get it to work and windows was able to reinstall, completely clean with no hassles.
Awesome, but then this is where things get worrisome:I noticed while the first drivers started to be updated(i plugged my phone in and the WD passport) the driver for the passport failed, I will get to that later. I start loading drivers for the GPU and wireless adapter, the wireless adapter's setup program was a little slow, but nothing too crazy, the GPU's app center on the other hand took much too long. At one point it stalled because of a "net framework error" and I hadn't even realized until I hit the little bubble to exit out of it. The rest of the drivers and what I assume to be bloatware finished installing and everything was a-ok again.
Wrong. I go to restore my backup from the passport, and nothing shows up. The only options were create a backup plan or restore a previous backup(which was completely empty.) Going into file explorer showed that indeed my backup and all the files were still there, and that the volume was about half full. None of the other applications on the passport worked, or for that matter would even install, and trying to install them only brought up the administrator tab( do you want to run this as blah blah) but nothing would happen afterwards. I go into devices and printers on the control panel and it shows that there was a problem with the driver, something about the SES device.
Fine, I can download steam and manually download the games, again, that I had installed already(if it even works that way)
I also begin to notice that my computer is running much too slowly for having 8 cores. Like really slow. Like I can't even move the cursor around without there being an unnecessary amount of lag, slow. I tell myself not to worry, and begin to download Arma3 to test out the new GPU. The download takes forever. Not because of the download time, but because whenever I would move the cursor around, it would add minutes onto the download time. I experimented with it at one point, and found that moving the cursor around added almost 30 minutes to my download time.....
This is when i begin to really worry, yet I start up Arma anyway and see what's going on. The game actually runs quite well, but the frame drop was consistent because of whatever was going on with my system. Nothing crashes, I got no error reports, no blue screens, my system is just running painfully slow, not only on a game I know it can handle, but just sitting as idle on the windows home screen,
I downloaded CoreTemp and it shows all cores are working at the correct frequencies, and at normal temperatures(highest was 29 at idle), task manager showed that cpu% never went above maybe 20, disk activity was only high when downloading Arma and my wifi is at full bars
My question is, what the heck gives!? BIOS itself had no problems, it takes maybe 5 or more seconds to POST, and my speaker gave no warnings other than when my RAM wasn't in properly. Is this something physically wrong with a component, a software problem, or what? I'm utterly confused and growing increasingly worried. I really need someone to point me in the right direction to begin fixing this problem, or at the worst, replacing parts or flat out returning them.
TL;DR new components, computer running really slowly, may be a CPU problem but nothing shows up.
