Hello,
My name is Joe. In 2010, I had some freinds help me build my first computer. I listed the parts below.
Motherboard - GA-EP45T-USB3 LGA 775
CPU - Intel Core 2 Quad Core Q8400 Yorkfeild
RAM - Geil Ultra GU34GM2200C9
Graphics Card - XFX Geforce GTS 250
HD - WD6401AALS 640GB 7200 RPM
I recently ordered and replaced everything here except for the WD Hard Drive(which I'm not sure if this is the issue. RPMs?, Cache?, No idea). The Hard was fine before I swapped out the parts. The new parts are.
Motherboard - GA-B85-HD2
CPU - Intel i5-4670K Haswell LGA 1150
RAM - Corsair Dominator(which was the wrong one, but I then I tried Corsair Vegence CMZ8GX3M2A1600C9B) Still same result below.
Graphics Card - Gigabyte GV-N760OC-2GD GeForce GTX 760
Here is the tricky part(for me at least). I want to use the same HD because I have a lot of stuff, but I also ordered a Seagate Constellation ES.3 ST1000NM0023.that I wanted to use as a slave HD. Is this the problem? If not can someone please explain the procedures? The bios on this new motherboard is badass, but I have no idea how to use it lol.
Finally, Once I Installed and hooked up my Corsair TV 850W PS to the parts, I turned it on, and it went to the Windows Starting scree, then froze, the blue screen flashed, then self repair, followed by shut down. Does it eeverytime(like 20 times).
Can somebody please explain what I need to do? I tried reseating everything, swapped memory(only because it was the wrong one in the first place, yet it does the same thing with the "right" memory, ei. freezes at start up), I messed with bios, but I am not too familiar so I stopped.
I sincerely appreciate your time for even reading, and would appreciate insightful responses even more. Please indulge me and help me out,
Thank you,
-Joe
Thank you,
-Joe
