Hello everyone, New here and looking for some advice/opinions.I have been away from building pc's for about 10 years and just getting back into it. So I guess I will start with my current specs.
Case = Hyte Y60 "White"
Motherboard = Rog Strix B550-A
CPU = Ryzen 9 5950X
CPU Cooler = Stock Cooler
Ram = Off brand 2133mhz x4 8g stix
GPU = GIGABYTE GeForce RTX 4070 Ti AERO OC V2
HDD = WD _ Black SN770 1TB
WD_BLACK 500GB
Monitor = SAMSUNG 49” Odyssey G9 Gaming Monitor, 1000R Curved Screen, QLED
So i would like to address the first issue in the list, Ram...My current motherboard can support 3200mhz. First question, How much of a difference would i notice with 3200mhz Ram?I am currently Looking at the Trident Royal 128g pack. I know that is a lot of ram but i like to play simulators and when i download a lot of assets, Also i plan on doing more then just gaming. 3d modeling/coding/video rendering. Just all kinds of stuff. I do want the ram to be rgb as right now i have 0 RGB in my case atm and i want to do something about it. So any suggestions?
Second issue is the cpu cooler. i am split atm, i am not sure if i want to go with fan cooling water cooler or just put a custom loop in. If i did the custom loop i would want to upgrade to another motherboard with a build on water block. Something like the ASUS ROG Maximus Z690 Formula. Also had another point. would changing to ddr5 ram be worth it? Or i could just go with the ASUS ROG Ryujin III.
Also if anyone could help with some good case fan options RGB of course and some RGB power cables. Just to make the case pop. The theme is white but i plan on making it into a theme of PennyWise the clown. That is the end game plan anyways. Thank you for the help
CPU = Ryzen 9 5950X
WD_BLACK 500GB
