G
Guest
Guest
CPU Intel Core i5-3570K 3.4GHz Quad-Core $219.95
CPU Cooler Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing $29.98
Thermal Compound Arctic Silver 5 High-Density Polysynthetic Silver 3.5g $6.73
Motherboard ASRock Z77 Extreme6 ATX LGA1155 $153.99
Memory Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 $77.99
Storage Western Digital Caviar Black 1TB 3.5" 7200RPM $79.98
Video Card MSI GeForce GTX 760 2GB $249.99
Case Rosewill THOR V2 ATX Full Tower $129.99
Power Supply Corsair 750W ATX12V / EPS12V $149.98
Optical Drive LG WH14NS40 Blu-Ray/DVD/CD Writer $54.99
Operating System Microsoft Windows 8.1 - 64-bit - OEM (64-bit) $99.98
Keyboard Rosewill RK-9000BL $86.98
Mouse Razer Razer Naga 2014 Wired Laser $59.99
This is the build im looking at getting, could someone help me find if the power supply will support the system and i have enough connectors for everything. also the gpu im going with is a pcie 3.0 will it work on a 3.0x16 or not? Theres no errors on pcpartpicker but i just wanted to double check. Also a side question being if its possible to run sli with a gtx 760 and a 770 or 780. Since theyre in the same series i think they can but ive heard nvidia can be a little more strict on what cards can run sli with one another. Thanks buds
