New Pc Build Using Old Parts As Base
TheR1pper
13
Approximate Purchase Date: As long as the entire computer is assembled [piece by piece if need be] Before 11/11/11
Budget Range: $952 before rebates
System Usage from Most to Least Important:Extreme Gaming AA,AF theworks,internet,small C++ Programming
Things i have on my current Rig that im hoping can be used in this build to save money:
Current GPU: NVIDIA GeForce 210 1 GB DDR2 Link: http://www.nvidia.com/object/product_geforce_210_us.html
Current Motherboard: MSI GF615M-P33 Link: http://www.msi.com/product/mb/GF615M-P33.html#/?div=Detail
Current CPU: AMD Phenom II x4 965 Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Current RAM: 2gigs DDR3 x2 4096MB or 4Gigs
Current case: Cooler Master, However if the new parts any of you suggest Dont fit in the current Case I would be more than willing to ghetto This $hit CardBoardBox Style. 😉
Current PSU: 480w
Preferred Website(s) for Parts: newegg.com, amazon.com, frys.com, tigerdirect.com
Other miscellaneous that i already have : Mouse,Keyboard,Moniters
Country of Origin: USA
Parts Preferences: As long as it is Great for gaming im fine, preferably for games requiring Direct x11
Overclocking: Most definitely ,But no i currently do not have a Cooling system for this.
SLI or Crossfire: I never have before but im all for it if recommended
Monitor Resolution: 1920x1080
Please let me know any suggestions you might have on building a new Rig while utilizing any of the parts of my current one.
Please leave links to the parts you suggest getting.
Thank you for your time.
From what I can see the motherboard is a very limiting factor.
It has no PCI 2.0 support. I would suggest upgrading to a new AM3 motherboard and picking up a new graphics card, something like 6870 or 6950 (if your budget can go that far).
Your pretty much looking for a decent overall build, minus the CPU. This could leave potential to upgrade to AMD's new BullDozer if you wanted to in the future.
The cheap way
Scythe SCMG-3000 120mm Heat Pipe CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185168
XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
XFX HD-695X-ZNDC Radeon HD 6950 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150524
and you keep motherboard, RAM and CPU. You overclock your CPU to 3,8 - 4,0 GHz and BAM. You can play everything!
325$ with MIR
