GIGABYTE f2a68hm-hd2
4GH HYPER FURY RAM 1866Mhz DDR3
A6-5400K CPU
KING DIAN 60GB SSD
SEASONIC 300w PSU
WINDOWS 7 PRO
No 1 , I had some issues installing windows 7 via both DVD and bootable USB options....it took FOREVER, I am talking 6 hours......that is not normal via current usb 2.0 speeds!
When trying to install chipset driver from disk and via downloading them they keep hanging at say 80 and again are taking WAY longer than usual.
windows explorer keeps crashing, it takes forever to open task manager, control panel etc , I cant understand exactly the issue.. my guess is some issue with the RAM.....which I will trouble shoot by getting my friend to bring round some DDR3 later today.
I have built upwards of 30 computers....so by no means a noob and I have never had such trouble getting windows installed on a new PC before, let alone all the trouble I am having at the moment.
Extra Info---!!
I have checked the SSD for errors ( being a cheap nasty one I looked at this first) and there are no errors here
All components are new
I used a 4 pin ATX 12v CPU power hook up instead of the 8 pin CPU power cable because this is all my seasonic PSU had available, so this leaves FOUR pins on the motherboards ATX 12V Port vacant.....I did NOT think this would be an issue as I have done this before and TBH I do not think that this could cause the issues I am having.
The next part is an observation which may yield a clue......THE HDD ACTIVITY LED on the front of the case is blinking like crazy anytime I click on something in the OS/ask the OS to do anything......I have read somewhere else that this can indicate an issue with RAM/ Paging/ problems accessing disk cache?
NO ISSUES WITH CPU TEMP-
I HAVE NOT UPDATED THE BIOS YET
HAVE NOT RUN MEMTEST YET ( ALTHOUGH I WILL)
WINDOWS EXPERIENCE INDEX CRASHED WHEN I TRIED TO USE IT, GIVING AN ERROR ABOUT THE KERNEL LOGGER.....NEVER HAD THIS HAPPEN BEFORE....
ANY HELP MUCH APPRECIATED, AND ALSO HAPPY NEW YEAR! 🙂
A6-5400K CPU
KING DIAN 60GB SSD
SEASONIC 300w PSU
WINDOWS 7 PRO
Extra Info---!!
