Question New PC Build wont power up.
cmduplain
67
8
Specs:
MB: Gigabyte X299X AORUS Designare 10G
CPU: Intel Core i9-9920X
PSU: 850w Supernova
Ram: 128gb Crucial DDR4
GPU: 2080ti Founders Edition
First motherboard I had would start for a few seconds and continue to restart. It had bent pins so I sent it back. Got a second motherboard, reseated everything, and only heard a click from the power supply. When nothing was plugged into the motherboard it would turn on for a few seconds as well. I have gone through and plugged everything in individually with no luck. Got a third new motherboard (the one im on now) and it is having the same problems. I have hooked up the PSU to another computer and everything powered up fine, so it isnt the power supply.
What steps should I take? What part could be the culprit?
