New PC for animation, rendering, and running games at high settings, for around $5500
KitingForDays
4
Hi, there Tomshardware! I've finally decided to make an account and start posting. I'm building a new PC from scratch and I'm looking for suggestions on a build I've put together on pcpartpicker.com (I'm using ca.pcpartpicker.com).
Approximate Purchase Date: September 2015
Budget Range: $4500-5000 CAD before shipping/rebates
System Usage from Most to Least Important: Rendering in Maya with IRay, Animation in Maya, 3D modelling in ZBrush, Architectural Visualizations, game development with Unity, CryEngine, and DirectX12, and playing games as high settings
Are you buying a monitor: No
Parts to Upgrade: It's an entirely new system
Do you need to buy OS: Yes (I've included it in the parts list after this template)
Preferred Website(s) for Parts: newegg.ca, canadacomputers.com, ncix.com, directcanada.com
Location: Sioux Lookout, Ontario, Canada (very rural town, no parts stores within a 4 hour drive)
Parts Preferences: Nvidia and Intel, otherwise I have no preferences here
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
Additional Comments: Noise isn't an issue; if it sounds like a jet taking off I'm totally okay with that. I was hoping to get some green internal lighting but wasn't sure what would fit in the case. I would also appreciate some advice on cooling; is what I have enough or should I get more fans/a bigger or more intense liquid cooler? I'm also trying to future-proof it a little bit, hence the graphics card I've picked out. I'm also going to stick to single-card setups since I've read of SLI issues for gaming and that most renders don't make use of multi-card setups (would appreciate correction if I'm wrong about this).
And Most Importantly, Why Are You Upgrading: I would like to have a system that I can render on and do CGI with at a good enough level to start freelancing. I played with Blender for a while 3 years ago and found that CGI is something I absolutely love doing. Game development is a secondary passion of mine that is almost as strong as that of CGI, but the only reason I really want to be able to run high-quality games is so that I can run test builds of games (you know, before optimizations).
The parts list I've assembled:
Intel Xeon E5-1650 V3 3.5GHz 6-Core Processor
Corsair H100i 77.0 CFM Liquid CPU Cooler
Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
MSI X99S Gaming 7 ATX LGA2011-3 Motherboard
G.Skill Ripjaws Series 32GB (4 x 8GB) DDR4-2400 Memory
Samsung 850 EVO-Series 120GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
EVGA GeForce GTX Titan X 12GB Superclocked Video Card
NZXT Phantom 820 (White) ATX Full Tower Case
EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply
LG UH12NS30 Blu-Ray Reader, DVD/CD Writer
Microsoft Windows 8.1 OEM (64-bit)
Creative Labs Sound Blaster Zx 24-bit 192 KHz Sound Card
Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter
So guys, do you think this system will meet the needs I have? Also, will this system even work/function? Any and all criticisms greatly appreciated.
Edit: I've updated the parts list above to reflect your guys' suggestions as well as some additional research I did.
It will work just fine. You have certainly got a good setup that will do pretty much everything you ask it to do. My only input is you could save yourself some money and go for the 5820k chip. You lose .2 GHz, but that's going to barely noticeable. I also recommend you go with a mechanical storage option (HDD) with your SSD. Use your SSD as a boot drive to load your OS and most-used apps, and use a mechanical HDD (like 1 or 2 TB) to store other media and other files you're working on for your professional projects. Get a WD Caviar Black drive. Just my 2 cents. I'd also go a bigger PSU-like 1000W. Stay with Seasonic, just get a 1000W gold unit. It's always better to have more PSU than you need for reliability. That Intel CPU and graphics...
It will work just fine. You have certainly got a good setup that will do pretty much everything you ask it to do. My only input is you could save yourself some money and go for the 5820k chip. You lose .2 GHz, but that's going to barely noticeable. I also recommend you go with a mechanical storage option (HDD) with your SSD. Use your SSD as a boot drive to load your OS and most-used apps, and use a mechanical HDD (like 1 or 2 TB) to store other media and other files you're working on for your professional projects. Get a WD Caviar Black drive. Just my 2 cents. I'd also go a bigger PSU-like 1000W. Stay with Seasonic, just get a 1000W gold unit. It's always better to have more PSU than you need for reliability. That Intel CPU and graphics card use a lot of juice when you push them. Otherwise, a good configuration for a versatile machine.
Hey, thanks for your advice! After applying your changes the system's price went down by about $450, which is always a welcomed change. Do you think the platinum rated PSU (same wattage and manufacturer) would be worth the extra $100 or so? I just read that the energy efficiency change from gold to platinum wasn't massive, but the articles were a 1-2 years old.
I would suggest maybe downgrading the ssd to like 500gbs or soomething like that to put any programs youre going to use for rendering, os, and stuff like that just for those startup times. Then spending some money on a 2-3 tb ahard drive because youre going to be using up alot of storage with all that video content and renders and all of that. The cpu upgrade suggested was nice. Your budget is huge so thats a nice plus.
