Hello,
I’ve recently built my first pc (intended for gaming), and after putting it together with the help of an experienced friend, it simply would not post or boot up via VGA or DVI. Once the pc is turned on, it only shuts off about 30 seconds later, then turns on by itself a few moments after it has been shut off automatically.
My current specs
ASRock AB350 PRO4 Motherboard
Ryzen 5 1500x processor
MSI Gtx 1050 2GB graphics Card (OC edition)
EVGA 430w Power Supply Unit
1TB WD blue HDD
Patriot Viper 2x4GB DDR4 RAM (2400MHz)
Zalman R1 Case
Troubleshooting methods I have tried
-Tested by for shortages in the pins and standoff’s (no shortages)
-Tried 2 different PSUs, One EVGA 500w and the other EVGA 430w
-Reset CMOS
-Manual On board BiOS reset
-Tested motherboard out of case on the box that the motherboard came in, (same exact result - no post and power cycle)
-Tested both sucks of ram in each slot about 3 times
-Quadruple checked all PSU connections for each PSU I tried
-complete reassembly
And with all these attempts the exact same result ensued, aka the power cycle and no post via DVI or VGA
Important note
-each of these components are brand new
-No CPU or On Board graphics (graphics supplied from gtx 1050
-each time power is turned on none of the fans act as normal, they are visibly slow to start up and maintain a slow rpm
Any help that fixes this heep and I will be eternally greatful
My current specs
1TB WD blue HDD
Zalman R1 Case
-Reset CMOS
Important note
