New PC power on first time, GPU not running
Louis Napoleon
Commendable
Oct 9, 2016
30
So I just finished building my first ever PC a hour ago. when I powered on the PC and enter the BIO ,what i had been noticing is that every components of the build was running except the gpu, Is that normal to every PC first power-on. or i might had installed the GPU wrong. Also, once I changed the BIO i just straight turned off the the power. and when i turned on again, the system didn't lead me to the BIO instead was a series of code let me plug in boot stuffi can't remeber exactly what it says. anyone has any idea of that . thank you very much
Louis Napoleon
Commendable
Oct 9, 2016
30
because there is no GPU data in the BIO, so i thought GPU won't work until you install the OS which I haven't
