Hi all,
I'm a hearing impaired person, but can hear with hearing aids. Recently, I have built a new PC system but I'm facing with a strange issue. When an audio has to be played, let it be a youtube movie or a game, I heard a very annoying sound from my speakers. I cannot describe it, but it sounds as trrtrtrtrrrrr but less "r". Like when you're waiting with your car in front of red light, but with less emphasis on the "rrr" sound. When I'm on desktop, that sound doesn't come out.
I have used that old speakers from my previous PC build, which made that noise. It's a Trust speaker
Close up:
I do have knowledge in PC components but I don't have much knowledge about audio systems (wouldn't surprise ya I guess). I thought that the speaker was broken, so bought another one. A Creative A50 speaker.
But that speaker is also having the same problem... Oddly enough, this tiny little cheapy speaker (i just tried that)
doesn't have that issue! It works on a battery while the other two here above is being powered by an USB.
I think that I have a ground loop issue. My motherboard is a MSI H110M gaming. I have tried everything on the software side ... (drivers, another ports, settings, ...). However I have to say that the case front audio ports (both micro and headphone) is not connected to the motherboard because I don't intent to use it. There is a lot cables to manage anyways...
Does it make a difference?
Now, can this issue being resolved or do I have look for another type of speakers? It doesn't have be that expensive set that you see here or on reddit because I'm hearing impaired (duh).
If I do have to look for another speakers, can someone point me which one I should take? Or point me the brands and which spec it should have (eg input model?) Or what I should do?
Close up:
