Hello everyone, i'm doing my first custom build. I've got most of the parts nailed down, but I'm unsure what I need/ should get in terms of a cpu cooler, power supply and case. I'm a photographer, and will be using Adobe Master Collection with primary use being in photoshop and bridge. I have a massive library of photos to be able to sort through and often work on huge layered files, (6 gb saved size). i got most of the components on Cyber Monday, but didn't know enough about the options to get the other parts then.
What i have already (purchased, so not looking for advice on these components):
intel i7 3770K processor
ASRock Z77 Extreme6/TB4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Kingston HyperX Black 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX16C10B1BK2/16X
EVGA 02G-P4-3651-KR GeForce GTX 650 Ti 2GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
3 of Seagate Barracuda 7200 3 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST3000DM001 (to run in RAID setup, probably RAID 5 but could use opinions on best way to set up)
SanDisk Extreme SSD 240 GB SATA 6.0 Gb-s 2.5-Inch Solid State Drive SDSSDX-240G-G25 (for operating system and programs)
I'm considering this power supply since Newegg has a sale on it for $89.99 after rebate:
High Current Pro HCP-750 750W TX12V v2.3 / EPS12V v2.92 SLI Certified CrossFire Certified 80 PLUS GOLD Certified Modular Active PFC Power Supply
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371052&Tpk=17-371-052&nm_mc=EMC-GD121712&cm_mmc=EMC-GD121712-_-index-_-Item-_-17-371-052
I don't know *** about power supplies or CPU coolers, so i could really use some advice there.
I also have no idea what case to get. i'd like to get a full tower, with lots of room and enough fans that I don't need a heatsink, although I may add one later when i overclock if its needed.
pros: quiet, dark-(I don't want a lot of led's or lights, since I will leave it uploading photos to the web while I sleep), easy to install components, expandable
Any advice is appreciated, but please bear in mind that I'm a newbie to this, so i don't know all the vocabulary.
Thank you!
Thank you!
