New power supply for an old pc
matizami
87
Hi Guys,
The power supply in my very old pc died and I'm looking for a new one. The thing is, the old one was 600W and it's quite expensive for this old pc. My mom uses it for Internet and emails, so I'm looking for a cheap one. My pc:
Q6600
GIGABYTE GA-P35-DS3L
G SKILL 4GB
ATI 6850
According to https://outervision.com/power-supply-calculator I need about 350W. Do you guys have any opinions?
that would be the next step. get/borrow a GPU for testing.
your testing the GPU and the PCIe slot. at this point both are suspect.
100W CPU + 125W GPU + maybe 40W for the balance = 265W absolute max load (which your mom won't be seeing if she's browsing the web).
300W would be fine, but you'll likely have to go a little higher to get some good quality PSUs. .
If you don;t mind mail-in-rebates, EVGA's 450B is a little under $30
https://pcpartpicker.com/product/MfvZxr/evga-450w-80-bronze-certified-atx-power-supply-100-b1-0450-k1
As is a Corsair CX450M
https://pcpartpicker.com/product/FQ648d/corsair-power-supply-cp9020101na
If you just want a low price without rebates, the Antec VP450 would be a solid option for the uses
https://pcpartpicker.com/product/MnR48d/antec-power-supply-vp450
While I wouldn't normally recommend these PSUs (apart from the Corsair CX450M), for the low power usage, they'd be fine.
Thanks for the quick reply!
I don't live in The US, so the models here are a bit different, and more expensive 🙁
Here's a list based on your recommendations:
Corsair CX450M 450W PSU 80+ Bronze Modular - about 60$
SeaSonic 520W 80+ Bronze S12II-520 -75$
SeaSonic 430W 80+ Bronze S12II-430 - 60$
Corsair 450W 80+ VS450 - 60$
Yeah, I know. It's expensive.
I bought Corsair CX430.
I connected the motherboard, CPU, GPU, Harddrive, CD. The fans of the CPU, GPU and the case run, but the pc won't load. There is no peep. Did I missed something?
Should I connect these cables?
