New power supply for crossfire? - Help
EggyDevil
53
Hello,
I currently have a VTX HD 6870 radeon and want to purchase another one in order to crossfire the two Gpus,
I have a Corsair cx500 (500w). Do i require more watts for crossfire and if so how much? The other problem is that each VTX HD 6870 radeon requires two 6pins and therefore i would need a Psu with 4x 6pins to fully connect both Gpus. Can anyone recomend me a good psu with enough watts as well as 4x 6pins?
Thanks,
Eggy :)
Hi - Yes you need a PSU with 4 pci-e connectors. But, need to know your
budget $$ for the PSU to recommend.
Tom
Hi again - realhardtechX suggests 600w(no harm in more) for 2 6870's in CF,
here's some 650w units to consider:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020 nets to $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012 nets to $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014 nets to $96
yes my max budget is 120$
