Odd, my power supply died a couple of days ago. So yesterday I replaced it with a Corsair CX750.
After installation, the power switch did nothing. Tried flipping the switch on the power supply, still nothing. So I started perusing my mobo user guide. I have an Asus M5A99X.
I noticed that with the power supply switch in the "on" position, I had a green led lit on the mobo.
My mobo has a switch on the lower right hand corner that takes you straight to bios setup.
I hit the button, and presto ! it started and took me to setup where I verified my settings and restarted, (through bios). Windows 10 started fine, and I even played Battlegrounds for a couple of hours, everything was working great.
This morning, I woke the computer up, (it hadn't been shut down since installing the new p.s., just put in sleep mode.) I got a blue screen, which hadn't happened in months. It said gathering information, we will restart for you. Well if got to 100% but never restarted, so I tried to hit the reset button, nothing...tried power button, nothing. Took the side off the case and hit the direct key button, and it powered up and went to bios setup again.
I checked under power options to make sure the settings for what the power button does when pressed hadn't changed, no change.
It's a hell of a hassle to have to take the side off the case just to start the damn thing. Anyone have any ides?
