New power supply
Mighty-bridge
7
Hello folks
Please help me choosing the correct UPS.
I like to buy Seasonic M12II-620 Bronze Evo Edition 620 , I live in india and now in summer there will be lots power shortage. So I need to buy a good UPS . But many websites say this Power supply is only compatible with sine wave output UPS. I can buy a expensive Sine wave ups if it is really necessary,but I can also spend that money to buy a good GPU in future . I am planning to buy a high end GPU in future .
I just need the UPS to protect it from constant low voltage and I only need five minutes of backup time , as I will shutdown the system once the power goes down.
I am building AMD FX 8350 system
My configuration
MOB Asus M5a99fx Pro R2.0
AMD FX 8350
Kingston FURY Memory - 8GB Module - DDR3 1866MHz CL10 DIMM
Transcend TS128GSSD370 128GB Solid State Drive
WD Elements 2TB USB 3.0 Portable Hard Disk
Asus NVIDIA GeForce GTX 750 TI OC 2 GB
Benq 21.5 LCD Full HD
Could you please let me know whether I can use this Power supply with
APC BR1100CI-IN UPS
http://www.amazon.in/APC-BR1100CI-IN-UPS/dp/B005Y8T0WW/ref=lp_1375343031_1_10?s=computers&ie=UTF8&qid=1432080431&sr=1-10
OR
APC UPS Model: BR1000G-IN 1 KVA Built in Battery
Or
I can also buy a Sine Wave Inverter UPS -
--( but this whole thing will be costly, I can go for this if it is really useful )
APC Home UPS 850VA Sine Wave BI850SINE
http://www.amazon.in/APC-Home-850VA-Sine-BI850SINE/dp/B009Y4BSAE/ref=lp_1375343031_1_6?s=computers&ie=UTF8&qid=1432080561&sr=1-6
And if I buy this I have to buy a separate battery, I can offered 100 AH or 90 AH battery .
Will 90 AH battery be enough ? cause its lot cheap and will easily fit in my budget.
PLEASE SUGGEST, if there any other similar power supply that will work with normal UPS.
I see Corsair CS650M is also in same range, will this work with any UPS ?
I already have purchased the MOBO and GPU.
I also need help with choosing AMD 8320 or AMD 8350. In your recent review I read both are same and AMD 8320 can be overclocked to work like 8350.
But I really dont want to overclock cause I want to keep it simple.
And I just want to know whether it is useful to spend the extra money to get AMD 8350 as it will run at 4 ghz in stock settings. If it gives me 5 - 10 fps more then I really dont mind spending the extra money .
Any help will be greatly appreciated!
Thank you
Thanks for replying, Yes I need a UPS for upgraded PC, I want to buy Seasonic M12II-620 Bronze Evo Edition 620 power supply .I wont be using any Speaker or Printers. But as I mentioned before this power supply requires pure sine wave, could you please suggest a good UPS for this power supply. It should be available in India . Could you please read my full thread
You should look on the Newegg UPS website and work out what UPS you want them see if its available in India
See http://www.newegg.com/UPS/SubCategory/ID-72
Then put in 10 mins run time, 6 outlets (?), run time 1-30 mins, 1000-2000W and 1000-2000VA to get
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007932%20600013485%20600013493%20600013480%20600013537
Then pick one
eg http://www.newegg.com/Product/Product.aspx?Item=N82E16842107015
and see if you can find it on amazon india.
If not then try another and so on till you find one that you're happy with.
