This is an Asus I bought about 8 years ago, CM6870. It had been in sleep/hibernate for a few weeks and yesterday I went to wake it up and it was off.. weird. I found the PSU that I had replaced about 5 years ago was bad (paperclip test) so I grabbed a new one, same watts, etc and put it in.
When I hit the power button all the fans start up for just a split second and then turn off. They do this every 3-5 seconds and nothing boots up or runs continuously. I'm getting a solid green light on the motherboard with no beeps or flashes to indicate the issue.
I've read through numerous similar issues on this forum and double checked connections, tried switching out ram sticks to different locations, even replaced the CMOS battery.
Currently, I have the motherboard removed from the case to eliminate possible shorts on the back of the mobo. Everything has been removed and disconnected from the mobo except the 24-pin power connector and the CPU 4+4 connector, and the power button connector and it's doing the same thing. The PSU fan starts for split second and stops, then it does this over and over every 4 seconds or so.
At this point, with everything removed (all RAM, GPU, fans, everything except power cords) I'm thinking it has to be either the CPU (Core i7 3770) or the board, correct? I would think that even in this stripped down state that I would at least get some kind of action past the green light and the PSA fan turning on and off constantly. It does this exact thing even with the CPU connector removed.
I removed the CPU just to see what happened and I still got the green light on the mobo but the PSU fan wouldn't even start that time.
Any suggestions would be appreciated!
