Question New Radeon Rx 460 GPU Problem
Dxlan
BANNED
Jul 14, 2019
44
I have an i5 2400 cpu and when I put the rx 460 in the motherboard it fits perfectly and all the fans are spinning.
Now the weird part is when I first installed it everything worked and the monitor turned on but everything was very slow.
I turned it off and back on , PC was working but then no monitor turning on. Help? I can also get pictures if you would like.
( The first connector i was using was a hdmi cable and then i switched to a dvi cable ,none seemed to work )
Kindly provide PC specs.
-1. "Complete" system specs should ALWAYS be accompanied with any driver, hardware, or performance question. Do not post DXDiag reports as they contain a TON of useless information. Posting a DxDiag in place of a System Spec List tends to ward off potential members from helping you.
Please supply the following system details/information:
(Complete System Specs)
-CPU make and model# (clock speed/voltage, type of cooler, and "Core" temperature @ idle and load)
-Motherboard make & model# (include Bios version if graphics card is not recognized or you are having stability issues)
-RAM (amount, clock speed, model#/link of kit, configuration)
-Graphics card(s) make and model# (clock speed, voltage if modified, Driver version and GPU temp both @ idle and load)
-Power supply make,model#, "AND" age (note if using 110V or 220V A/C input)
-HDD/SSD configuration (ie: Raid setup/ back up/ OS drive/etc..)
-Case/Chasis make,model# (fan make, model#, and configuration if having thermal issues)
-Operating System (If using Windows note Framework and service pack version)
-Monitor make, model#, and resolution (If model# is unknown list resolution and refresh rate)
*If the unit is a "laptop" or "All-in-one" system you must note the make and model# of the unit. Be sure you are ALWAYS using the OEM/manufacturer's Driver updates for the unit.
*If "Crashing":
-Note the nature of the "crash" in detail, as there are several definitions for the word "crash".
*If "performance" related issue:
-Note the "exact" point in which the performance reduction occurred (ie: After Windows update, After Bios update, After Driver update, After thermal system shutdown, After Hardware change/upgrade etc...)
*For diagnostic purposes please disable the following:
-Any/all Antivirus/ Anti-malware software
-Any/all OSD monitoring software
-ALL overclocks outside of factory spec
*If "Crashing":
Im sorry this is my first ever thread
I5 2400 quad core processor
Radeon RX 460 2GB Graphics Card
4GB Ram
This is all I know im not really a pro in this stuff
By the way, when I take the GPU out and everything works.
You are missing most of the specs, motherboard, PSU, BIOS version, Windows OS build. So, if you remove the GPU, the system boots properly vi the onboard graphics/iGPU ?
