New rig, Motherboard power LED on but no boot.
Motherbeard
21
Hello guys,
I am new to the 'homemade' PC community and I recently bought parts to build a completely new rig myself. I have installed everything using the internet and manuals but I only get a green power LED on my motherboard. I have tried everything, (Including the standard checklist guide on tomshardware.uk) double check all the connectors, get the motherboard out of the case and place it on a cardboard box, clear BIOS (using the button), MemOk!, using only one RAM slot etc etc but it still does not work. The power LED turns green when connecting the PSU but when I try to start it, it doesn't do anything at all.
Specs:
Mobo: Asus Sabertooth z77
CPU: Intel i7 3770k
CPU cooler: Corsair H100i
SSD: Samsung 256 GB 840 Pro series
RAM: Corsair 2x8 GB 1600 MHz Vengeance
PSU: Corsair AX 650
Case: Fractal Design Define R4
GPU not installed, will get one soon.
I'm a relative newbie when it comes to hardware so I request the help of you experts here
I think that the 'Motherboard' forum is relevant enough to place it here.
I hope that someone can help me, thanks.
Yeah, that sounds like pretty dismal performance from the PSU, even without a load on it. After that, you are looking at the CPU/MOBO, but PSU is sounding fairly likely.
I shorted the power pins and already had the CPU_FAN header connected, it still doesn't boot. I have uploaded some pics to give you a view on the situation (Note: The power connector from the case is not connected because I tried to short it)
I guess a imgur link is ok, http://imgur.com/a/JWydB
Thanks for the quick reply
i would disconnect the drive and the cables from it to the motherboard - install the other ram stick (it's Dual channel)
have you made sure your power connections are secure?
------------ UPDATE
I just noticed, based on your picture, that you have the single RAM stick in the wrong slot - taken from page 2-5 of the manual, it should be in the 2nd slot closest to the cpu
Those would be my two first suggestions as well, there could be an issue with the drive/cable/sata port, and your supplemental CPU power may not be fully inserted, I think the light would be indicative that the 20+4 pin is plugged in correctly.
Yes, and as Dingo pointed out, you need to put it in the appropriate slots.
I have inserted the RAM both single slot and dual slot correctly now, still no boot. Also without the SSD connected not any activity at all.
Did you make sure all your connectors were firm? And you were careful in installing the CPU? I know it sucks removing the heatsink but you might wanna check for damage to the socket/CPU as a last resort, make sure you have some spare thermal paste on hand, and also make sure non leaked off the top of the chip.
The [strike]PSU[/strike] fans do not have molex connections, the controller does have one but still no activity at all. The paperclip test is hard to do since all the cables are sleeved black.
EDIT: Case fans, ofcourse
I checked it really well when I applied the cooler, I will do this when nothing else works at all.
Don't take any offense I am just trying to be thorough, from my knowledge, you simply short the pins inside of the plastic connector for the paper clip test, the sleeved area shouldn't have anything to do with it. Is that what you were trying to do? You could also try removing the 30mm fans from their headers, see if for some reason one of those is causing an issue.
No, I meant that the usually coloured cables are black. I now know which ones I need to short, disconnecting the 30mm fans does not work. Could it possibly be a DOA motherboard/PSU?
Just follow the pin out he provided, orient it in the same direction as the diagram, and short the green pin to the black one next to it. I think you want everything unhooked when doing this, it will basically see if your PSU can turn on at all. Watch his vid if you need further info. At this point, it is likely the CPU, MOBO, or PSU. The paperclip test can rule out the PSU.
Done, I hear a high-pitched noise, the fan turns on after 5 secs on around 15 RPM and turns down. I will post a vine video in a few mins.
UPDATE: Now the PSU doesn't do anything more at all. Not even the 15 RPM spin. Here is the Vine video. https://vine.co/v/bEFvLDLKVia
Completely turn it off and unplug it, give it a minute or two to discharge it's capacitors, plug it back in and try (the paperclip test) again. If it is still a no go, I would say you have a bad PSU. That seems a little sluggish even without a load on the PSU.
Retried it after 5 minutes with disconnecting everything, a bleak 10 RPM spin for ~3 seconds then stopping again. I need to RMA it indeed. Thanks for the help guys!
So, RMA?
Thanks. I will RMA it to the Corsair point here directly. Thanks for the help guys, I wish I could pick more answers as a solution. I guess this can be closed because I'll open a new topic when my replaced PSU also doesn't work.
Greetings,
Max
I just remembered that the PSU only turns the fan on on about 150W load so I can't be sure if it really is the PSU, I have contacted Asus and I hope that I'll hear something from them.
