Please don't spam the forum, keep it to 1 thread.
Hi all.
I am planning on building a new rig in the next few days/weeks.
This is the following build:
https://de.pcpartpicker.com/list/gPdkp8
I could not find every item, so I just took similar ones.
Main differences:
A. What PSU to get -
Main differences:
- I will try to buy an used GTX970 or something like a 1060.
- Different case.
- I am not sure if a 450W unit will be sufficient.
- These are some PSU's I am considering:
- be quiet! ATX 500W System Power 9. BN246
- EVGA 450, 80+ Bronze
- Corsair CX450M
- Something else under 50-60 Euros. (And yes, I really do not want to spend 90 Euros on a PSU)
- Ideally, I would not want to do a Bios update, as I do not even have any other AMD chips.
- I am unsure if these are already compatible with the 3000 series, I will ask the sellers as well, but if you guys already know something...
- ASRock A320M-DVS R4.0
- Asus Prime B450M-A
- Gigabyte B450M Gaming Motherboard Buchse AM4 AMD B450 Micro ATX - Motherboards (DDR4-SDRAM, DIMM, 2133,2400,2667,2933 MHz, Dual, 32 GB, AMD)
- Do you guys know of something that is "guaranteed" to work, and under 70 Euros? My philosophy on PSU's is, "as cheap as possible, that does the bare minimum required"
