G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I am building up a new rig. I decided to build up the basic system
BEFORE I bolted it down in the case so the board is on the bench.
Specs:
A7N8X
Athlon 2800+ Barton
Stock CPU/HSF
Crucial 512 stick in slot 1
ATI 9600SE
Antec Smartpower 350
The unit will not power up. Fans will not turn and no beeps.
The onboard LED is "on" when power is present.
I have jumpered the ATX Power Switch to simulate "being in the case".
The PS was tested ok with Antec ATX tester.
All parts are new.
I have removed the battery to clear the CMOS.
I have removed the memory stick - no beep codes.
Any ideas on how to isolate the problem?
Thanks,
PeteH
Specs:
A7N8X
Athlon 2800+ Barton
Stock CPU/HSF
ATI 9600SE
All parts are new.
Thanks,
PeteH
