Hey!
I just built a new pc to simply get a better performance overall and stream here and there but I feel like something is not right the way it works.
It sometimes just feels sluggish and playing games like Fortnite is sometimes unplayable because of the FPS drops.
I pretty much play every game on the lowest settings and sometimes even with a lower resolution but in Fortnite especially it's pretty bad on this setup for me.
And I feel like it must be my memory settings?
Setup:
Ryzen 5 1600 (boxed cooler)
G.Skill Aegis 16GB DDR4 RAM 3000 MHz
PowerColor Red Devil RX 570 4GB
MSI B350M PRO-VDH
Samsung SSD 860 EVO 250GB
Toshiba DT01ACA 1TB
be quiet! System Power 7 500W
I have the latest driver for my GPU and the BIOS seems up to date aswell since I tried to scan it with MSI Live Update.
I also activated the second XMP profile in my BIOS to get my RAM close to 3000 MHz.
BIOS Screenshots:
https://imgur.com/a/ZqTXj7q
But on CPU-Z it's still has the frequency of around 1066 MHz.
It tells me aswell that it's working on Dual Channel. So that's fine?
I also tried to disable the XMP profile and manually adjust the speed but it's still the same.
Might this be the problem?
CPU-Z Screenshots:
https://imgur.com/a/Drkm63n
Temperature seems fine aswell.
CPU is around 30-45 C and GPU can go up to 60-70 C (is that too high?) while gaming.
On BIOS I have Smart Fan on and pretty much everything on defaul on AMD's settings.
I also installed MSI Afterburner to adjust the fan speed but doesn't really help.
Any help would be appreciated!
Setup:
MSI B350M PRO-VDH
Toshiba DT01ACA 1TB
BIOS Screenshots:
CPU-Z Screenshots:
