Archived from groups: comp.sys.laptops (
More info?)
Pete D wrote:
> "Andrew" <usenetMYSHOES@bizaveMYSHOES.com> wrote in message
> news:caczcasdaxczcasd90303622811@bizaveMYSHOES.com...
>> Pete D <no@email.com> wrote:
>>> Bought my daughter a new laptop, a Sony VGN-B55G VAIO. Ethernet
>>> connects to my ADSL router but wireless will connect but not get a
>>> network address (static does not work either), other PC's connect
>>> using Netcomm USB wireless adapters but the Netcomm adapters will
>>> not work in the Sony laptop.
>> Are you sure your router does not have MAC Address Filtering (where
>> you must choose which computers to allow on the wireless network)
>> turned on? What about WEP or WPA encryption? Or is your wireless
>> network completely open?
>> When the Sony has connected to the wireless network (but without an
>> address), do this:
>> Start -> Run
>> type "cmd" and Enter key
>> You're in a command window.
>> in the command window, type "ipconfig" and type the Enter key.
>> No IP address?
>> What type of router is it? 802.11b or 802.11g? The laptop is most
>> likely g but that should be compatible with b.
>> Besides a software enable, is there a toggle switch or button on the
>> Sony somewhere to turn on the wireless card? Are you sure it's on?
>> Have you tried taking the laptop to a place like Starbucks that has
>> WiFi and see if you can connect? Starbucks isn't free WiFi but you
>> can at least get a signup screen for free and if that works, you know
>> the laptop wireless is at least working.
>> Andrew
> Ethernet works perfectly.
> MAC address filtering is disabled
> 802.11b IP address not needed as I am running a DHCP server on the
> router, even when I put in a static address on the laptop it still
> comes up with "limited or no connectivity".
> Other PC's login to the router just fine using Netgear USB wireless
> adapters just fine, with security or without. .
Make sure that the checkbox "Let Windows Manage this Connection" is
checked; the setting 802.11x Authentication is unchecked. In
Administrative Tools/Services, Wireless Zero Configuration service is
set to Automatic start and is running.
Q
