New sound card plays sound but my mic doesn't work?
JollyJed
53
Hey guys,
I bought myself an 'Asus Xonar DG PCI' sound card and installed it today along with the driver but unfortunately its not picking up my mic.. it will play sound but my mic wont work :/ the mic on the headset works perfectly fine as i have tested it on my laptop..
What have i done wrong?
Thanks guys
Hello, Jed.
I assume you run on Windows OS, if not - I am not at power to help you.
I might sound a bit naive, but have you tried fiddling with your sound settings? You can access those in your Notification area, right from task-bar by right-clicking White Speaker Icon and selecting recording devices. When you open the window select recording tab and try speaking into microphone. If you see white bars filling up on one of the rows - click that row and press "Set Default". Also try to reinstall the sound card (remove drivers, take out card, boot pc, shut down pc, put in the soundcard and install drivers) - always worth trying. Then again you could try to install the sound card into your other PC or friend's computer to check if the sound card is at fault, hence making it returnable for warranty. I hope you
Did you connect the Mic cable to the sound card you bought and not in the integrated Motherboard's? Just doublecheck, because I've had similar solution myself 😀
Hey I had the same issue with a creative soundblaster card.
If your sound card has an audio panel interface program thing where you can adjust bass/treble/speaker settings open it and look for a tab that deals with the cards INPUTS. This is where i had to tell it that I had plugged a microphone into the jack. Weird but it started working instantly. Hope this helps!!
See the image where there is a tab for the input jacks---second to last option?
Both wires are definitely connected to the sound card mate, am i right in saying that the only cable that needed to be connected to the sound card is the HD AUDIO cable and nothing else
I have something called Xonar DG Audio center, was it something like that?
It could be for your card. Open that up and look for anything related to your inputs (plugs) and microphone options.
I had to select it as my mic through the windows "Recording Devices" AND through my sound card options.
unfortunately there is nothing for inputs 🙁 - http://gyazo.com/29bf553059cd05b6164149cf149311f4
